[SOLVED] J-link Virtual Com port doesn't work
  • [SOLVED] J-link Virtual Com port doesn't work
    I recently started working with the Jlink Edu. I need the Vcom port but it doensn't seem to work.
    I have read the manual and another post regarding the isssue but it doensn't seem to do anything.
    I can initialize the port using the conigurater or the commander. I also see the port in my devices under windows.
    But when i connect pin 5 to 17 and send some data nothing seems to happen.
    When i use HTerm to connect i take a baut rate of 38400 but i also tried other speeds.
    There are no problems connecting to the device, but i dont see the data i send comming back.
    I will put some screenshots to clarify.
    Thanks in advance
    greets,
    Bjorn
    To be able to use J-Link's VCOM port J-Link needs to know the voltage level of the high and low levels it can use.
    For this VTref and GND must be connected.
    More information can be found here: wiki.segger.com/Using_J-Link_V…M_functionality_and_speed
    Attached is the output of a successful test.
    The test can easily be replicated using our measurement adapter: segger.com/products/debug-prob…easurement-patch-adapter/
  • Hello Bjorn,
