[SOLVED] [Ozone] Setting a breakpoint callback function on function call when the source location is unknown
  • [SOLVED] [Ozone] Setting a breakpoint callback function on function call when the source location is unknown
    I can easily set a breakpoint on a function:
    1. Break.SetOnSrc ( "myFunction" );
    However, I cannot set a breakpoint callback function if I don't know the source location (the line number may change, so I need to consider it as "unknown").
    I can use Elf to get the address of the function and use that to set a breakpoint. I would like to use the following to set the callback:
    1. address = Elf.GetExprValue( "&myFunction" );
    2. Break.Set ( address );
    3. Break.SetCommand ( address, "callback" );
    However, that will fail as SetCommand expects the source location to be a string literal.
    Is there some way to convert 'address' to a string? I tried using an array of char, but passing 'array' to SetCommand gets "Expected a '['" and '&array[ 0 ]' gets "Expected a value or an identifier".
    Unfortunately currently there is no such functionality to use SetCommand with an address or to convert a number to a string.
    We will add a new function called SetCommandOnAddress or similar that will be able to work with numbers.
    It should be available with the next Ozone release version.
