[SOLVED] [Ozone] JLINK reading memory from invalid address
  • [SOLVED] [Ozone] JLINK reading memory from invalid address
    I am starting to use Ozone with J-Link (Ultra+) on an ARM Cortex A9 architecture. I manage to connect to the target and to make first debugging steps.
    The startup code (and data) are located in internal RAM at memory address 0xFFFF0000.
    After a few single steps, I tell the debugger to run to the next breakpoint which is set at the entry to the main function.
    Inside the main function, the first instruction is:
    PUSH {R4-R5,R11,LR} (with the stack pointer being correctly set)
    This makes the J-Link isse a JLINK_ReadMemU32(0x600FC89C) comand.
    The memory address 0x600FC89C is not in the device's memory map and thus it fails.
    After this step, I can no longer step with the debugger.
    Any idea, why J-Link makes the read access to an invalid address?
    I have extended the j-link log data. Here is the last bit that ends up with the illegal memory access:
    T0F20 15297:897 JLINK_Step() -- CPU_ReadMem(64 bytes @ 0xFFFF4E40) -- Updating DA cache (64 bytes @ 0xFFFF4E40) -- Read from DA cache (4 bytes @ 0xFFFF4E68) -- Not simulated -- CPU_WriteMem(4 bytes @ 0x80110100) -- CPU_WriteMem(4 bytes @ 0x80110140) -- CPU_WriteMem(4 bytes @ 0x80110104) -- CPU_WriteMem(4 bytes @ 0x80110144) -- CPU_WriteMem(4 bytes @ 0x80110148) -- CPU_WriteMem(4 bytes @ 0x8011014C) -- CPU_WriteMem(4 bytes @ 0x80110150) -- CPU_WriteMem(4 bytes @ 0x80110154) returns 0x00
    (0023ms, 45405ms total)
    T0F20 15297:920 JLINK_ReadReg(R13_SVC) returns 0xFFFFF5E8 (0002ms, 45407ms total)
    T0F20 15297:922 JLINK_ReadReg(R15 (PC)) returns 0xFFFF4E6C (0000ms, 45407ms total)
    T2BBC 15297:923 JLINK_ReadRegs(NumRegs = 18, Indexes: 0, 1, 2, 3, 4, 5, 6, 7, 10, 11, 12, 13, 14, 26, 27, 9, 8, 25) -- R0=0xFFFFE5FC, R1=0xFFFFE5F8, R2=0x00, R3=0x00, R4=0xFFFFE1E8, R5=0xFFFFFD14, R6=0x00, R7=0x00, R8_USR=0x00, R9_USR=0x00, R10_USR=0x00, R11_USR=0x00, R12_USR=0x00, R13_SVC=0xFFFFF5E8, R14_SVC=0xFFFF0100, R15 (PC)=0xFFFF4E6C, CPSR=0x600001D3, SPSR_SVC=0x600F4884 returns 0x00 (0004ms, 45411ms total)
    T2BBC 15297:928 JLINK_GetDebugInfo(0x10F = JLINKARM_DEBUG_INFO_HAS_CORTEX_M_SECURITY_EXT_INDEX) returns 0xFFFFFFFF (0000ms, 45411ms total)
    T0F20 15297:928 JLINK_ReadReg(FPS26) returns 0x600F4884 (0044ms, 45455ms total)
    T0F20 15297:973 JLINK_ReadMemU32(0x600F489C, 0x0001 Items, ...) -- CPU_ReadMem(4 bytes @ 0x600F489C) returns 0xFFFFFFFF (0021ms, 45476ms total)
    15298:546 JLINK_IsHalted() returns TRUE (0001ms, 45477ms total)
    It seems to be related to register FPS26, I guess.
    Btw. my SoC is a single core Altera (Intel) Cyclone V.
    The post was edited 2 times, last by alemannia ().
    Which Ozone version are you using?
    Could you provide your Ozone project .jdebug and the .elf file?
    Could you provide the Ozone log of such an event?
    How to enable Ozone Log: launch "Ozone --logfile <logfile>" where <logfile> is the logfile path. More information are available in the Ozone manual.
    We received your inquiry per e-mail as well.
    For future inquiries try to keep everything to one communications channel as inquiries from different channels will only slow down our response time as all data has to be gathered from multiple sources first.
    We found the cause for the read of FPS26 and at its value and fixed it.
    The fix will be included in the update, planned for Friday.
