J-Link script compiler or interpreter errors
    • J-Link script compiler or interpreter errors
      for trying to get the FCR4 scripts working with J-Link software V632c, i found that the code is compiled or interpreted wrong.
      It can observed that when using function results directly, garbage is returned. Workaround seem to be using temporary variables for the results.
      1. int TestFunc(void)
      2. {
      3. int result;
      4. result = 0;
      5. //Report1(" TestFunc: ", result);
      6. return result;
      7. }
      8. void CallEvalFunc1(void)
      9. {
      10. int temp;
      11. Report(" CallEvalFunc1: entry");
      12. temp = TestFunc();
      13. if (temp != 0)
      14. {
      15. Report1(" ***if (temp != 0)***", temp);
      16. SYS_Sleep(750);
      17. }
      18. else
      19. {
      20. Report(" else.1");
      21. }
      22. Report(" CallEvalFunc1: exit");
      23. }
      24. void CallEvalFunc2(void)
      25. {
      26. Report(" CallEvalFunc2: entry");
      27. if (TestFunc() != 0)
      28. {
      29. Report(" ***if (TestFunc() != 0)***");
      30. SYS_Sleep(750);
      31. }
      32. else
      33. {
      34. Report(" else.2");
      35. }
      36. Report(" CallEvalFunc2: exit");
      37. }
      38. void CallEvalFunc3(void)
      39. {
      40. Report(" CallEvalFunc3: entry");
      41. if (0 != TestFunc())
      42. {
      43. Report(" ***if (0 != TestFunc())***");
      44. SYS_Sleep(750);
      45. }
      46. else
      47. {
      48. Report(" else.3");
      49. }
      50. Report(" CallEvalFunc3: exit");
      51. }
      52. void CallEvalFunc4(void)
      53. {
      54. int temp;
      55. Report(" CallEvalFunc4: entry");
      56. temp = TestFunc();
      57. Report1(" a) TestFunc() temp: ", temp);
      58. Report1(" b) TestFunc() direct: ", TestFunc());
      59. temp = TestFunc();
      60. Report1(" a) TestFunc() temp: ", temp);
      61. Report1(" b) TestFunc() direct: ", TestFunc());
      62. Report(" CallEvalFunc4: exit");
      63. }
      64. void ResetTarget(void)
      65. {
      66. Report("ResetTarget() from JLinkScript is executed");
      67. }
      68. void InitTarget(void)
      69. {
      70. Report("InitTarget: extry");
      71. CallEvalFunc1();
      72. CallEvalFunc2();
      73. CallEvalFunc3();
      74. CallEvalFunc4();
      75. Report("InitTarget: exit");
      76. }
      output on V612i is:
      1. InitTarget: extry
      2. CallEvalFunc1: entry
      3. else.1
      4. CallEvalFunc1: exit
      5. CallEvalFunc2: entry
      6. else.2
      7. CallEvalFunc2: exit
      8. CallEvalFunc3: entry
      9. else.3
      10. CallEvalFunc3: exit
      11. CallEvalFunc4: entry
      12. a) TestFunc() temp: 0x00000000
      13. b) TestFunc() direct: 0x00000000
      14. a) TestFunc() temp: 0x00000000
      15. b) TestFunc() direct: 0x00000000
      16. CallEvalFunc4: exit
      17. InitTarget: exit
      output on V632c is:
      3. else.1
      6. ***if (TestFunc() != 0)***
      9. else.3
      13. b) TestFunc() direct: 0x00000139
      15. b) TestFunc() direct: 0x00000139
      The post was edited 2 times, last by Veit_Kannegieser ().
    • New
      It seem to be a compiler problem in JLinkARM.dll,
      i have looked with a debugger, and found that for the
      indirect function result usage it generates:
      1. // temp = TestFunc();
      2. push R0 // Save registers in use
      3. call TestFunc
      4. mov R1, R0 // Save return value
      5. pop R0 // Restore registers
      6. str R1, [SP] // temp
      7. // Report1(" a) TestFunc() temp: ", temp);
      8. mov R11, _StrLit13
      9. ldr R12, [SP] // temp
      10. push R11-R12
      11. apicall 48, 2 // Report1
      so the result travels R0 -> R1 -> [SP] -> R12 -> push.
      however for direct case:
      1. // Report1(" b) TestFunc() direct: ", TestFunc());
      2. mov R11, _StrLit14
      3. call TestFunc
      4. mov R12, R11
      5. push R11-R12
      6. apicall 48, 2 // Report1
      the function result in R0 gets ignored and the string address gets pushed in both R11 and R12.
