[SOLVED] J-Link Remote Server Unknown EMU command #28
  • [SOLVED] J-Link Remote Server Unknown EMU command #28
    I'm using J-Link tools version 6.32c and trying to test the remote server function with a USB J-Link. I run remote server on one Windows 10 machine. I then launch J-Link Commander on the second Windows 10 machine within the same LAN.
    After executing a connect command I eventually receive a message box on Remote Server stating "Unknown EMU command #28 received. Discontinuing parsing of communication".
    Thank you for your help,
    Jim
    Below is a capture of the Commander console and error.
    J-Link>connect
    Please specify device / core. : STM32F412RG
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    S) SWD
    TIF>S
    Specify target interface speed [kHz]. : 4000 kHz
    Speed>
    Device "STM32F412RG" selected.
    Connecting to target via SWD
    Device will be unsecured now.
    AP[0]: Core found
    FPUnit: 15 code (BP) slots and 15 literal slots
    CoreSight components:
    ROMTbl[0] @ E00FF000
    ****** Error: Communication timed out: Requested 4 bytes, received 0 bytes !
    Cannot connect to target.
    The issue is already known and has been internally fixed.
    A fixed release is planned to be available in the next 1-2 weeks.
    To stay up to date with our J-Link software releases we suggest subscribing to our notification list:
    segger.com/notification/subscribe.php?prodid=7
