J-Link with ASIC (R5, M0+): Unable to Connect to Target
    • J-Link with ASIC (R5, M0+): Unable to Connect to Target
      I have a custom board for a custom ASIC. The ASIC has R5 and M0+ cores.
      I have wired VCC, GND, RESET, TMS, TCK, TDI and TDO from the board to the J-Link's 20 pin header.
      When I give connect, I get the option to choose the CPU core which was selected as Cortex-R5. But the debugger is unable to connect to the target.
      Commander log is given below:
      SEGGER J-Link Commander V6.32b (Compiled May 8 2018 18:26:51)
      DLL version V6.32b, compiled May 8 2018 18:26:33
      Firmware: J-Link V9 compiled Apr 20 2018 16:47:26
      Hardware version: V9.30
      S/N: 269307276
      License(s): FlashBP, GDB
      OEM: SEGGER-EDU
      VTref=2.887V
      J-Link>connect
      Please specify device / core. : CORTEX-R5
      Type '?' for selection dialog
      Device>
      J) JTAG (Default)
      S) SWD
      TIF>J
      Device position in JTAG chain (IRPre,DRPre) : -1,-1 => Auto-detect
      JTAGConf>
      Specify target interface speed [kHz]. : 4000 kHz
      Speed>
      Device "CORTEX-R5" selected.
      Connecting to target via JTAG
      TotalIRLen = ?, IRPrint = 0x..000000000000000000000000
      Cannot connect to target.
      Please let me know the exacts steps to connect and debug the target.
      Raj
    • Hello Raj,
      Generally R5 cores are supported and should at least return some information when J-Link tries to connect to them.
      According to your log J-Link does not get any response whatsoever.
      Could you check if your wiring is compatible to the one described in the J-Link user manual?
      Depending on your ASIC implementation additional init steps are needed. For this J-Link Script files can be user.
      More information about them can be found in the J-Link user manual as well.
      How to add support for unsupported target devices the following guide can be used: wiki.segger.com/Adding_Support_for_New_Devices
      We noticed that you are using a J-Link EDU.
      Are you using the J-Link EDU for a commercial project? Keep in mind that a J-Link EDU may only be used for evaluation purposes and educational/private use, any other use would violate the license agreement.
