[SOLVED] problem getting RTT working with STM32H743ZI and Ultra+
  • [SOLVED] problem getting RTT working with STM32H743ZI and Ultra+
    I'm trying to get RTT working on an STM32H743ZI and it doesn't log to terminal window and I can't get the J-Link RTT viewer to find the RTT control block in my CPU memory.
    I'm using J-Link V6.22f with an Ultra+
    I first tried to call SEGGER_RTT_WriteString, which setup the signature block. I connected RTT viewer, and log another SEGGER_RTT_WriteString, but no output to the Terminal window.
    The menu Logging / Channel Infos says "RTT control block not found on target, yet."
    I manually use J-Mem to find the RTT control block at 0x200196a4. I disconnect the RTT viewer and reconnect, but this time specifying the RTT control block at this memory. It connects properly, but the "Logging / Channel Infos" says the same thing and no logging goes to the terminal window.
    Thoughts?
    Thanks...Keith Rhodes
    Generally we recommend using the latest J-Link software to have all new features and benefits of our regularly updated software.
