Ozone + JLinkRemoteServer "Unknown EMU command #28 received"
    • Ozone + JLinkRemoteServer "Unknown EMU command #28 received"
      I am trying to use Ozone 2.56e with JLinkRemoteServer 6.32b ARM (raspberry pi). Unfortunately communication seems to break down.
      Thank you for help.
      On the server end I get:
      1. *** J-Link Remote Server V6.32b Warning ***Unknown EMU command #28 received. Discontinuing parsing of communication.
      2. *** J-Link Remote Server V6.32b Warning ***
      3. Client disconnected.
      4. Waiting for client connection... Client connected.
      5. *** J-Link Remote Server V6.32b Warning ***
      6. Unknown EMU command #28 received. Discontinuing parsing of communication.
      7. *** J-Link Remote Server V6.32b Warning ***
      In Ozone log I see:
      1. J-Link: Connecting to J-Link via TCP/IP (xxxxxxxxxx:19020)
      2. p, li { white-space: pre-wrap; }
      3. J-Link: Connected with SEGGER J-Link Remote Server V6.32b compiled 18:30:30 on May 8 2018
      4. J-Link: Device "MK12DN512XXX5" selected.
      5. J-Link: InitTarget()
      6. J-Link: Found SW-DP with ID 0x2BA01477
      7. J-Link: Scanning AP map to find all available APs
      8. J-Link: AP[2]: Stopped AP scan as end of AP map has been reached
      9. J-Link: AP[0]: AHB-AP (IDR: 0x24770011)
      10. J-Link: AP[1]: JTAG-AP (IDR: 0x001C0000)
      11. J-Link: Iterating through AP map to find AHB-AP to use
      12. J-Link: AP[0]: Core found
      13. J-Link: AP[0]: AHB-AP ROM base: 0xE00FF000
      14. J-Link: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
      15. J-Link: Found Cortex-M4 r0p1, Little endian.
      16. J-Link: FPUnit: 10 code (BP) slots and 15 literal slots
      17. J-Link: CoreSight components:
      18. J-Link: ROMTbl[0] @ E00FF000
      19. J-Link: ROMTbl[0][0]: EE0FF000, CID: ED200001, PID: ED200001 ???
      20. J-Link: connected to target device
      21. Debug.Start();
      22. Connection failed
      23. Debug.SetConnectMode (CM_DOWNLOAD_RESET);
      24. Debug.Start();
      25. J-Link: Connecting to J-Link via TCP/IP (xxxxxxxxxxx:19020)
      26. J-Link: Connected with SEGGER J-Link Remote Server V6.32b compiled 18:30:30 on May 8 2018
      27. J-Link: Device "MK12DN512XXX5" selected.
      28. J-Link: InitTarget()
      29. J-Link: Found SW-DP with ID 0x2BA01477
      30. J-Link: Scanning AP map to find all available APs
      31. J-Link: AP[2]: Stopped AP scan as end of AP map has been reached
      32. J-Link: AP[0]: AHB-AP (IDR: 0x24770011)
      33. J-Link: AP[1]: JTAG-AP (IDR: 0x001C0000)
      34. J-Link: Iterating through AP map to find AHB-AP to use
      35. J-Link: AP[0]: Core found
      36. J-Link: AP[0]: AHB-AP ROM base: 0xE00FF000
      37. J-Link: CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
      38. J-Link: Found Cortex-M4 r0p1, Little endian.
      39. J-Link: FPUnit: 10 code (BP) slots and 15 literal slots
      40. J-Link: CoreSight components:
      41. J-Link: ROMTbl[0] @ E00FF000
      42. J-Link: ROMTbl[0][0]: EE0FF000, CID: ED200001, PID: ED200001 ???
      43. J-Link: connected to target device
      44. J-Link: connection to target device lost.
      45. J-Link: CPU could not be halted
      46. J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
      47. J-Link: Reset: Reset device via AIRCR.SYSRESETREQ.
      48. J-Link: Reset: SYSRESETREQ has confused core.
      49. J-Link: Reset: Using fallback: VECTRESET.
      50. J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
      51. J-Link: Reset: Reset device via AIRCR.VECTRESET.
      52. J-Link: Reset: CPU may have not been reset (DHCSR.S_RESET_ST never gets set).
      53. J-Link: Reset: Using fallback: Reset pin.
      54. J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
      55. J-Link: Reset: Reset device via reset pin
      56. J-Link: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
      57. J-Link: Reset: Reconnecting and manually halting CPU.
      58. J-Link: CPU could not be halted
      59. J-Link: Reset: Core did not halt after reset, trying to disable WDT.
      60. J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
      61. J-Link: Reset: Reset device via reset pin
      62. J-Link: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
      63. J-Link: Reset: Reconnecting and manually halting CPU.
      64. J-Link: CPU could not be halted
      65. J-Link: Reset: Failed. Toggling reset pin and trying reset strategy again.
      66. J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
      67. J-Link: Reset: Reset device via AIRCR.SYSRESETREQ.
      68. J-Link: Reset: SYSRESETREQ has confused core.
      69. J-Link: Reset: Using fallback: VECTRESET.
      70. J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
      71. J-Link: Reset: Reset device via AIRCR.VECTRESET.
      72. J-Link: Reset: CPU may have not been reset (DHCSR.S_RESET_ST never gets set).
      73. J-Link: Reset: Using fallback: Reset pin.
      74. J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
      75. J-Link: Reset: Reset device via reset pin
      76. J-Link: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
      77. J-Link: Reset: Reconnecting and manually halting CPU.
      78. J-Link: CPU could not be halted
      79. J-Link: Reset: Core did not halt after reset, trying to disable WDT.
      80. J-Link: Reset: Halt core after reset via DEMCR.VC_CORERESET.
      81. J-Link: Reset: Reset device via reset pin
      82. J-Link: Reset: VC_CORERESET did not halt CPU. (Debug logic also reset by reset pin?).
      83. J-Link: Reset: Reconnecting and manually halting CPU.
      84. J-Link: CPU could not be halted
      85. J-Link: InitTarget()
      86. J-Link: Connect Under Reset
      87. J-Link: Communication error while accessing MDM-AP.
      88. J-Link: Connect Under Reset
      89. J-Link: AfterResetTarget()
      90. J-Link: Could not read hardware status!
      91. DAP error while reading DP-Ctrl-Stat register.
      92. InitTarget(): PCode returned with error code -1
      93. Elf.GetBaseAddr();
      94. Target.SetReg ("SP", 0x0);
      95. Target.SetReg ("SP", 0x0): not connected
      96. Target.SetReg ("PC", 0x0);
      97. Target.SetReg ("PC", 0x0): not connected
      98. J-Link: disconnected from target device
      The issue regarding unknown emu command #28 is already known and fixed internally. A fixed release is planned in the next two weeks.
      However it usually appears as a follow up error to a previous more generic problem when interfacing the hardware. Looking through your logs this seems to be the case here.
      Could you try a generic connect using the J-Link Commander directly without J-Link Remote Server? wiki.segger.com/J-Link_cannot_…ty_using_J-Link_Commander
      Is your device locked? Could you try command unlock kinetis? Make sure the dialogue is not disalbed: wiki.segger.com/Kinetis_Series…s#Secured_device_detected
    • Okay - I'll wait for the fix.
      Just for your info: the very same setup worked fine on Windows locally with Ozone or J-Flash Lite + remote desktop, but was not as convenient if I had Ozone running on my development machine. Remote server on Windows gave identical #28 error.
