emwin calendar
    • emwin calendar
      Hi
      In my parent window when i click a button i open a calendar dialog. i would like to know once i click in someother part of parent window how the calendar dialog can be hidden like under which event i can handle this situation. i tried during WM_PAINT where i am keep checking whether calendar window is visible && has not captured touch && has focus i will disable but its happening once i create the calendar i want to handle this kind of feature when user touches any other place other than widgets in parent window the calendar dialog gets hidden.
      Simply react on WM_TOUCH of the parent window (the dialog in the example below) and delete the calendar.
      1. #include "DIALOG.h"
      3. *
      4. * Externals
      5. *
      7. */
      9. *
      10. * Defines
      11. *
      12. **********************************************************************
      13. */
      14. #define ID_WINDOW_0 (GUI_ID_USER + 0x00)
      15. #define ID_BUTTON_0 (GUI_ID_USER + 0x01)
      16. /*********************************************************************
      17. *
      18. * Static data
      19. *
      20. **********************************************************************
      21. */
      22. /*********************************************************************
      23. *
      24. * _aDialogCreate
      25. */
      26. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
      27. { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 480, 272, 0, 0x0, 0 },
      28. { BUTTON_CreateIndirect, "Calendar", ID_BUTTON_0, 20, 20, 80, 20, 0, 0x0, 0 },
      29. };
      30. /*********************************************************************
      31. *
      32. * Static code
      33. *
      34. **********************************************************************
      35. */
      36. /*********************************************************************
      37. *
      38. * _cbDialog
      39. */
      40. static void _cbDialog(WM_MESSAGE * pMsg) {
      41. WM_HWIN hItem;
      42. int NCode;
      43. int Id;
      44. switch (pMsg->MsgId) {
      45. case WM_NOTIFY_PARENT:
      46. Id = WM_GetId(pMsg->hWinSrc);
      47. NCode = pMsg->Data.v;
      48. switch(Id) {
      49. case ID_BUTTON_0: // Notifications sent by 'Calendar'
      50. switch(NCode) {
      51. case WM_NOTIFICATION_RELEASED:
      52. //
      53. // Get CALENDAR handle and check if already opened, if not create a calendar
      54. //
      55. hItem = WM_GetDialogItem(pMsg->hWin, GUI_ID_CALENDAR0);
      56. if (!hItem) {
      57. CALENDAR_Create(pMsg->hWin, 20, 20, 2018, 5, 8, 2, GUI_ID_CALENDAR0, WM_CF_SHOW);
      58. }
      59. break;
      60. }
      61. break;
      62. }
      63. break;
      64. case WM_TOUCH:
      65. //
      66. // On touch, check if CALENDAR is present, if true delete it
      67. //
      68. hItem = WM_GetDialogItem(pMsg->hWin, GUI_ID_CALENDAR0);
      69. if (hItem) {
      70. WM_DeleteWindow(hItem);
      71. }
      72. //
      73. // Call default handler
      74. //
      75. WM_DefaultProc(pMsg);
      76. break;
      77. default:
      78. WM_DefaultProc(pMsg);
      79. break;
      80. }
      81. }
      82. /*********************************************************************
      83. *
      84. * _cbBk
      85. */
      86. static void _cbBk(WM_MESSAGE * pMsg) {
      87. switch (pMsg->MsgId) {
      88. case WM_PAINT:
      89. GUI_SetBkColor(GUI_DARKGREEN);
      90. GUI_Clear();
      91. break;
      92. default:
      93. WM_DefaultProc(pMsg);
      94. break;
      95. }
      96. }
      97. /*********************************************************************
      98. *
      99. * Public code
      100. *
      101. **********************************************************************
      102. */
      103. /*********************************************************************
      104. *
      105. * MainTask
      106. */
      107. void MainTask(void) {
      108. GUI_Init();
      109. WM_SetCallback(WM_HBKWIN, _cbBk);
      110. GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
      111. while (1) {
      112. GUI_Delay(100);
      113. }
      114. }
      115. /*************************** End of file ****************************/
    • hi
      thanks
      i tried its getting deleted if i touch on the parent window but if i selecting any date in the calendar that time also its getting deleted.
      i would like to delete the calendar once the user click on parent window not when he is selecting any date in the calendar r doing right left scroll to change the month
    • hello sven
      also i would like to know about the scroll buttons provided in calendar. as when i press the scroll buttons rarely it changes the months.
      how can i manually increment decrement months based on case WM_NOTIFICATION_SCROLL_CHANGED: where i need to identify which scroll button is pressed left or right one.
      thanks
