I am using Segger JLink to download my binary to flash using the Eclipse IDE.
Eclipse IDE version is Oxygen.3a Release (4.7.3a) and I am using the GDB Segger Jlink Debugging to download the binary to flash.
When I try to download I get the following error on the debug console. Can you help me resolve this error. Once I physically disconnect the debugger and reconnect again, things start working fine.
Thank you.
Radhika
SEGGER J-Link GDB Server V6.30f Command Line Version
JLinkARM.dll V6.30f (DLL compiled Mar 2 2018 17:29:18)
Command line: -if swd -device NEBO -endian little -speed auto -port 2331 -swoport 2332 -telnetport 2333 -vd -ir -localhostonly 1 -singlerun -strict -timeout 0 -nogui
GDBInit file: none
Terminal I/O port: 2333
Generate logfile: off
Verify download: on
Init regs on start: on
Silent mode: off
Single run mode: on
J-Link Host interface: USB
J-Link script: none
J-Link settings file: none
Target device: NEBO
Target interface: SWD
Target interface speed: auto
Target endian: little
Connecting to J-Link...
J-Link is connected.
Firmware: J-Link V10 compiled Mar 2 2018 17:07:17
Hardware: V10.10
S/N: 600108394
Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
Checking target voltage...
Target voltage: 3.30 V
Listening on TCP/IP port 2331
Connecting to target...ERROR: The connected J-Link (S/N 600108394) is low on memory. Target connection cannot be established
ERROR: Could not connect to target.
Target connection failed. GDBServer will be closed...Restoring target state and closing J-Link connection...
Shutting down...
Thank you.
Radhika
GDBInit file: none
Verify download: on
Silent mode: off
Single run mode: on
J-Link script: none
Target device: NEBO
Hardware: V10.10
S/N: 600108394
Shutting down...
