[ABANDONED] ERROR: Could not find CFI compliant flash device
  • [ABANDONED] ERROR: Could not find CFI compliant flash device
    I Have imx283 Board.
    I am trying to connect using J-Link Plus but it is giving erroe as show below Log:
    Application log started
    - J-Flash V6.16g (J-Flash compiled Jul 10 2017 16:40:31)
    - JLinkARM.dll V6.16g (DLL compiled Jul 10 2017 16:40:10)
    Creating new project ...
    - New project created successfully
    Connecting ...
    - Target interface speed: 1000 kHz (Fixed)
    - VTarget = 3.385V
    - Executing init sequence ...
    - Initialized successfully
    - J-Link found 1 JTAG device. Core ID: 0x079264F3 (None)
    - Connected successfully
    Reading entire flash chip ...
    - 1 sector, 1 range, 0x0 - 0xFFFFFFFF
    - Start of determining flash info (Bank 0 @ 0x00000000)
    - ERROR: Could not find CFI compliant flash device
    - Error while determining flash info (Bank 0 @ 0x00000000)
    - End of determining flash info
    - Flash bank info:
    - 1 * 0 bytes @ 0x00000000
    - ERROR: Failed to read back target memory
    Which board are you trying to program?
    Is it an eval board or custom hardware?
    Which external Flash are you trying to program?
    For the iMX2 series external Flash download is not supported by default.
    J-Flash can currently only program a CFI compliant external Flash that has been configured by the user.
    More information about this can be found in the J-Link user manual in section "Setup for various debuggers (CFI flash)".
    If you are looking for a custom Flash loader for your setup our open Flash loader interface can be used: wiki.segger.com/Adding_Support_for_New_Devices
