OMAP L137
    • Hi I am trying to connect to a OMAP L137 EVM using a JLink Plus and the script
      This is what comander reports
      SEGGER J-Link Commander V6.31h (Compiled Apr 5 2018 16:04:47)
      DLL version V6.31h, compiled Apr 5 2018 16:04:28
      Firmware: J-Link V10 compiled Mar 29 2018 17:45:34
      Hardware version: V10.10
      S/N: xxxxxx
      VTref = 3.354V
      J-Link>connect
      Please specify device / core. <Default>: ARM9
      Type '?' for selection dialog
      Device>
      J) JTAG (Default)
      TIF>
      Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
      JTAGConf>
      Speed>
      Device "ARM9" selected.
      Connecting to target via JTAG
      TotalIRLen = 6, IRPrint = 0x01
      JTAG chain detection found 1 devices:
      #0 Id: 0x9B7DF02F, IRLen: 06, TI ICEPick
      ****** Error: CPU-TAP not found in JTAG chain
      Cannot connect to target.
      Any suggestions ?
      Thank you
      developerR
      The OMAP-137 device is not supported by J-Link. The OMAP-138 is however.
      If they are similar enough you could try to select OMAP-L138 instead of ARM9 in J-link commander.
      Simply specifying ARM9 will not work for this specific device as special handling is needed.
    • Hi Nino
      I thought it set
      CPU=ARM926EJS;
      from the script
      tried
      JTAGConf>
      Speed>
      Device "OMAP-L138" selected.
      TotalIRLen = ?, IRPrint = 0x..000000000000000000000000
      ****** Error: AM18xx (connect): Cannot find ICE-Pick (IRLen mismatch)
      ****** Error: AM18xx (connect): Cannot identify CPU core. Read JTAG Id 0x07926001, expected 0x00000000
      Thanks for your help
      what script do you mean?
      There is no script that we provide for the L138 device.
      Simply select the device name and connect should work without any scripts for the L138. If the L137 hardware is similar enough it should also work.
      The script that you are referring to is ancient and is no longer compatible with the OMAP-L138 initialization in the current J-Link software.
      We do not recommend using it for OMAP-L138.
      Please understand that we can't offer support for old JLinkScripts that are not provided through the official release channels.
      As there is little market interest for the L137 and our resources are currently booked with more pressing projects we will not be adding support for that device at this point in time.
      However you can use the Script as baseline to implement support on your own. The L137 is a dual Core SoC so the Cores most likely need to be enabled through the ICEPick first.
      For more information consult the target devices manual and TI.
