Programming external Macronix MX25 flash with JFlashSPI
  • Programming external Macronix MX25 flash with JFlashSPI
    I am trying to flash an external memory MX25R8035FM1IL0 using JFlashSPI. I looked at the supported flash list but it does not appeared, do you have some advice to do this operation?
    Best Regards,
    The MX25R8035FM1IL0 is currently not implemented by auto detection.
    This will be added with the next J-Link software update expected tomorrow.
    For now you can add the device manually to your J-FlashSPI project.
    Go to Options->Project Settings->Flash
    Deselect "Automatically detect SPI flash" and insert all necessary information from the Flash user manual.
    After that programming should work as expected.
