[SOLVED] Cannot compile std::map initialization from initializer list
  • [SOLVED] Cannot compile std::map initialization from initializer list
    Good morning,
    I am trying to compile the following code (SES 3.34, G++ 6-2017-q2, option -std=c++11 set):
    1. #include <map>
    2. #include <stdint.h>
    3. class Test
    4. {
    5. enum class ENumber
    6. {
    7. Zero, One, Two
    8. };
    9. typedef std::map<uint32_t, ENumber> Map;
    10. static const Map theMap;
    11. };
    12. const Test::Map Test::theMap =
    13. {
    14. { 0, Test::ENumber::Two }
    15. , { 2, Test::ENumber::One }
    16. };
    and get this error message:
    1. testmap.cpp:23:1: error: could not convert '{{0, Two}, {2, One}}' from '<brace-enclosed initializer list>' to 'const Map {aka const stlpmtx_std::map<unsigned int, Test::ENumber>}'
    The code seems correct to me, and it compiles without complaints natively on my Ubuntu PC (g++ 5.4)
    Is there a way I can do this with STLport?
    Can you point me to a site where the current STLport subset is documented?
    Thank you,
    Achim
  • Hello Achim,
    This should be doable with STLPort.
    You can install it using the package manager: Tools->Package Manager...->STLPort library
    To make it available in your project open project settings, then Code->Libraries->STLPort Library->set to yes.
    Does that work with your setup?
  • Hello Nino,
    STLport Library Package, Version 1.00 is installed - otherwise I would see "std::map is not a type" or even "map: no such file". It doesn't work.
    I do use std::map in my project, but I cannot initialize one this way.
    Does it work on your site?
    Achim
    The post was edited 2 times, last by Achim O. ().
  • Hello Achim,
    The STLPort shipped with ES is only 100% c++98. Some C++11 and 14 extension have been added but not for std::map yet.
    So to be able to initialize your map with ES you can do as follows:
    1. class Test
    2. {
    3. Test() {
    4. theMap[0] = Test::ENumber::Zero;
    5. theMap[1] = Test::ENumber::One;
    6. theMap[2] = Test::ENumber::Two;
    7. };
    8. enum class ENumber
    9. {
    10. Zero, One, Two
    11. };
    12. typedef std::map<uint32_t, ENumber> Map;
    13. static Map theMap;
    14. };
    We will discuss internally if a std::map extension for c++11 can also be added to support your code. But no promises.
