[SOLVED] Using .jlinkscripts with Ozone
  • [SOLVED] Using .jlinkscripts with Ozone
    Hello:
    I have a .jlinkscript file that is being passes to jlink.exe with NXP's MCUXpresso Tool. I wish to use it within Ozone. The syntax appears the same as what is in a .jdebug file used by ozone. Can I copy the source into a .jdebug file?
    What is the proper way to use a .jlinkscript file in an ozone project? (I attached what I am using. I had to add the .txt extention to allow an uplaod to this forum)
    To keep your .jdebug as slim as possible we suggest using function Project.SetJLinkScript to insert the JLinkScript in the Ozone project. More information about this can be found in the Ozone user manual in section 7.8.11.22 Project.SetJLinkScript.
    You can call this command anywhere in the Ozone script, but as this seems to be an SDRAM init we suggest doing so in Function AfterTargetReset();
