[SOLVED] Can't type hash?
    What version of macOS are you running?
    Does the same issue appear with ES V3.34?
  • Hi folks.
    I have similar problem. Using OSX 10.13.1 and SES 3.34a. I'm mainly using Estonian keyboard layout and following characters '[', ']', '{', '}' all need alt-modifier (alt+8, alt+9, alt+7, alt+0).
    Having SES 3.34 and SES 3.34a simultaneously open, in SES 3.34 I can type {[]} (alt+7 - alt+0), whereas in SES 3.34a nothing happens (except right-alt+0 toggles buld panel). Tested with both right and left alt.
    Keys using alt modifier arent working. The problem seems to be that alt modifier is blocked by SES keybindings (shortcuts) (I have reset these to factory defaults), becuase right-alt+0 toggles the bottom build panel. left-alt+0 doesnt.
    The described keyboard issues under macOS should be fixed with the latest release version V3.34b.
