[SOLVED] External tool not appearing in macOS?
  • [SOLVED] External tool not appearing in macOS?
    I'm trying to set up CMSIS Configuration Wizard in Segger embedded studio as detailed by Nordic. My resulting tools.xml file:
    1. <tools>
    2. <!-- PC-lint - http://www.gimpel.com/html/pcl.htm -->
    3. <if host_os="win">
    4. <item name="Tool.PClint">
    5. <menu>&amp;PC-lint (Unit Check)</menu>
    6. <text>PC-lint (Unit Check)</text>
    7. <tip>Run a PC-lint unit checkout on the selected file or folder</tip>
    8. <key>Ctrl+L, Ctrl+P</key>
    9. <match>*.c;*.cpp</match>
    10. <message>Linting</message>
    11. <commands>
    12. &quot;$(LINTDIR)/lint-nt&quot; -v -incvar(__CW_ARM) -i$(LINTDIR)/lnt co-gcc.lnt $(DEFINES) $(INCLUDES) -D__GNUC__ -u -b +macros +macros -w2 -e537 +fie +ffn -width(0,4) -hF1 &quot;-format=%f:%l:%C:\s%t:\s%m [-e%n]&quot; &quot;$(InputPath)&quot;
    13. </commands>
    14. </if>
    15. <item name="Tool.CMSIS_Config_Wizard" wait="no">
    16. <menu>&amp;CMSIS Configuration Wizard</menu>
    17. <text>CMSIS Configuration Wizard</text>
    18. <tip>Open a configuration file in CMSIS Configuration Wizard</tip>
    19. <key>Ctrl+Y</key>
    20. <match>*config*.h</match>
    21. <message>CMSIS Config</message>
    22. <commands>
    23. java -jar &quot;$(CMSIS_CONFIG_TOOL)&quot; &quot;$(InputPath)&quot;
    24. </commands>
    25. </item>
    26. </tools>
    This doesn't work – the option doesn't appear in the context menu, even after restarting SES, see attachment. Am I doing something wrong?
