[ABANDONED] Ozone - remap source files
  • [ABANDONED] Ozone - remap source files
    I've just started using Ozone under Windows 10. I build my code using Cygwin. The resulting .elf file specifies the source files with a "/mnt/c" prepended to each source path/file name. When I open the project in Ozone, I get "File not found" errors due to the extra path at the beginning of each file that Cygwin adds. Is there a way to tell Ozone to remap these files to the path it understands? I tried typing Project.AddPathSubstitute ("/mnt/c", "/"); into the Console window, but that did not have any affect.
    Thanks!
    Try using the project dir macro with the absolute path added that gets output as error in Ozone instead:
    Project.AddPathSubstitute("C:/work/Test", "$(ProjectDir)"); for example.
    Does that work for you?
