[SOLVED] Embedded Studio 3.34 + Ozone 2.56e + i.MXRT1052 EVK Issue
  • [SOLVED] Embedded Studio 3.34 + Ozone 2.56e + i.MXRT1052 EVK Issue
    Hello:
    I am having a debug issue with the NXP i.MX RT1052EVK with Ozone.
    Setup:
    Ozone 2.56e
    i.MXRT1052 EVK
    Using External J-LINK debugger on J21
    The board is jumpered to boot from HyperFlash (although I am only testing RAM only projects).
    What is Working:
    I was abel to create the sample Hello world project in Embedded Studio after installing the 1-52 support package. It could compile and download fine. I could single step, etc withing embedded studio. Hellow World messages showedup in the debug terminal.
    Problem:
    I prefer to use the ozone debugger. From the "Debug" menu I selected "Debug With Ozone". Ozone startup successfully. When to tried to download, ozone froze here. (Screenshot attached).
    I eventually get "failed to read target status. Abort Debug Session".
    I think this may be an ozone issue as I can debug in embedded studio.
    Also, I have also debugged via NXP's MCUXpresso tool. I would like to get Ozone up an running as it has been the best debug tool
    For this particular device to work with Ozone you need to uncomment the functions TargetReset() and AfterTargetDownload() in the .jdebug file.
    To do this simply save the Ozone project and edit the .jedebug file.
    Does this work for you?
  • Hello Nino:
    Thank you for the response.
    I followed your instructions:
    1.) Saved the .jdebug file
    2.) Uncommented the functions TargetReset() and AfterTargetDownload()
    It seems to get a little further in the process but still hangs. I have attached my .jdebug file that was created by Embedded Studio launching Ozone as well as a capture of the console when the freeze occurs.
    Note: I had to rename the .jdebug to .jdebug.txt to allow upload to the forum.
    The post was edited 1 time, last by Eli Hughes ().
  • Just a bump on this.
    I recently grabbed Jlink6.31d (beta). Ozone now appears to work. My test application can single step, etc.
    I did notice that there a couple i.MX RT1052 options.
    in particular there is a
    MIMXRT1052xxxxA
    and a
    MIMXRT1052xxxxB
    What is the difference?
    I looked in the JLinkdevices.xml
    "A" and "B" appear to be identical as they both use a hyper flash driver.
    I though one might be for QSPI flash programming but "NXP_iMXRT105x_QSPI.elf" is never specified. (I found NXP_iMXRT105x_QSPI.elf in the JLink_V631d\Devices\NXP\iMXRT105x folder).
    If I do want QSPI, can I simply edit the .XML file to use the correct driver?
    Thanks!
    Great to hear that Ozone works now for you.
    A and B should be 99% identical. The difference between them should be described in the target device reference manual.
    How to switch between Hyperflash and QSPI is described here: wiki.segger.com/IMXRT105x
