Virtual keyboard
    • Virtual keyboard
      Hi
      i did some test with a slightly modified version of keypad.c (found in this forum) called from a dialog window (with 2 edit widget). When I run the dialog and press one of the edit widgets an event (WM_NOTIFICATION_CLICKED) is triggered and the virtual keyboard (in edit.c) is called. To work properly i need to disable the dialog (in keypad.c) because sometimes the virtual keyboard is called more than once. Apparently the callback mechanism of the dialog is called from inside the vurtual keyboard and this triggers the keyboard again. Is this solution (disable the dialog) the best solution to fix this ?
      The post was edited 1 time, last by Mr. Spock ().
