We are planning to use ATMEL AT91SAM7 (ARM7) controller together with embOS. I am short with pins, therefore I am thinking about using the USB device interface with its dedicated pins as debug interface. ATMEL supplies a USB framework and code to implement CDC serial driver (virtual com port). Any suggestions or hints, if this configuration will work together with embView?
There is an older thread with related topic about debugging over TCP/IP.
