[ABANDONED] Embedded Studio crashes on ubuntu
  • [ABANDONED] Embedded Studio crashes on ubuntu
    version: Segger Embedded Studio v3.34a for arm
    OS: Linux 4.13.0-36-generic #40-Ubuntu SMP x86_64 x86_64 x86_64 GNU/Linux - Ubuntu 17.10
    installation worked without any percievable problems
    steps to reproduce:
    launch using system menu. During initialization, it crashes.
    I have tried to remove all user config files in ~/.segger and ~/.config/
    I don't know how to find the crash log if any. There are no details when it crashes to help me troubleshoot.
    Possibly I could use some help in diagnosing the problem.
    Lance
  • Hello Lance,
    Did the issue start right after installation or did you create a project and the issue appeared afterwards?
    Could you provide us with your emProject file and emSession file if you created a project?
    Could you attach the settings.xml as well which is located in the Embedded Studio user folder?
    After you attached the requested files does deleting the settings.xml and emSession file (if available) solve the issue?
