the best way to show an hourglass animation
      there are several ways of implementing an hourglass in emWin.
      If it should stick to the cursor you could use the function GUI_CURSOR_SelectAnim(). You could use the default animated cursor (which is an hourglass) or create your own. Please refer to the API description of GUI_CURSOR_SelectAnim() in the manual.
      If the hourglass should be drawn somewhere on the screen you could also draw a GIF-animation using the GIF related API.
      A third method might be to use a sprite and draw it on the screen (this is more or less the same as a cursor).
