[SOLVED] Rust support in Ozone?
  • [SOLVED] Rust support in Ozone?
    I used Ozone with a Rust program on a STM32 and my expierience was not really good.
    Most time it looks like Ozone can not relate source to machine code at all. (I thought debugging info ist language independent?)
    Also it does not recognise the Rust data types in the watch window.
    Is there any Rust support planned? That would be great!
    Ozone is a C/C++ debugger. Other programming languages might work but it is not guaranteed.
    This is quite possible as Ozone does not handle Rust specific data types.
    Currently there are no plans to do so.
  • We also (in my company) use Rust and Ozone as a debugger.
    It is true, watch data types and watch expression are not supported, however the rest seems fine. Ozone seems to have trouble recognizing data types sizes.
    The Global/Local Data successfully recognizes rust variables. If you want to check the value of the data you have to right click and check the variable value in the memory browser itself.
    You can also recognize rust functions and files in the source and function viewer.
    I suppose this all work because in the end the debug symbols are pretty much language abstract.
    Alessandro
