How to display "Δ" Symbol using emwin
      1. You need a font which contains the desired character (the default fonts do not contain this character so you have to create one with the Font Converter).
      2. Convert the string into a UTF8 string. For the "Δ" character it is "\xce\x94". To generate it on your own create a UTF8 decoded txt file and paste the desired string into it. Then convert the txt file with U2C.exe into a c file. It will contain the UTF8 encoded "c"-string.
      3. In your application enable UTF8 encoding by a call of GUI_UC_SetEncodeUTF8(), set the font with the character and display the UTF8 string.
      Here is a short example how this can be achieved:
      1. #include "DIALOG.h"
      3. *
      4. * Defines
      5. *
      7. */
      9. *
      10. * Static data
      11. *
      12. **********************************************************************
      13. */
      14. /* Start of unicode area <Basic Greek> */
      15. GUI_CONST_STORAGE unsigned char acGUI_FontDelta_0394[666] = { /* code 0394, GREEK CAPITAL LETTER DELTA */
      16. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x4F, 0xFF, 0xFF, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      17. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x9F, 0xFF, 0xFF, 0xB0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      18. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xFF, 0xF2, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      19. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0xFF, 0xFF, 0xFF, 0xF7, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      20. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xFF, 0xFC, 0xFF, 0xFD, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      21. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xF3, 0xFF, 0xFF, 0x40, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      22. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x9F, 0xFF, 0xD0, 0xBF, 0xFF, 0xA0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      23. 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xEF, 0xFF, 0x80, 0x6F, 0xFF, 0xF1, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      24. 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0xFF, 0xFF, 0x20, 0x1F, 0xFF, 0xF6, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      25. 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0xFF, 0xFB, 0x00, 0x0A, 0xFF, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00,
      26. 0x00, 0x00, 0x00, 0x00, 0x00, 0x2F, 0xFF, 0xF4, 0x00, 0x04, 0xFF, 0xFF, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00,
      27. 0x00, 0x00, 0x00, 0x00, 0x00, 0x8F, 0xFF, 0xE0, 0x00, 0x00, 0xDF, 0xFF, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00,
      28. 0x00, 0x00, 0x00, 0x00, 0x00, 0xEF, 0xFF, 0x90, 0x00, 0x00, 0x8F, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00,
      29. 0x00, 0x00, 0x00, 0x00, 0x05, 0xFF, 0xFF, 0x30, 0x00, 0x00, 0x3F, 0xFF, 0xF6, 0x00, 0x00, 0x00, 0x00, 0x00,
      30. 0x00, 0x00, 0x00, 0x00, 0x0B, 0xFF, 0xFD, 0x00, 0x00, 0x00, 0x0D, 0xFF, 0xFB, 0x00, 0x00, 0x00, 0x00, 0x00,
      31. 0x00, 0x00, 0x00, 0x00, 0x2F, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x08, 0xFF, 0xFF, 0x20, 0x00, 0x00, 0x00, 0x00,
      32. 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xF3, 0x00, 0x00, 0x00, 0x02, 0xFF, 0xFF, 0x80, 0x00, 0x00, 0x00, 0x00,
      33. 0x00, 0x00, 0x00, 0x00, 0xDF, 0xFF, 0xC0, 0x00, 0x00, 0x00, 0x00, 0xCF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00,
      34. 0x00, 0x00, 0x00, 0x04, 0xFF, 0xFF, 0x70, 0x00, 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xF5, 0x00, 0x00, 0x00, 0x00,
      35. 0x00, 0x00, 0x00, 0x0A, 0xFF, 0xFF, 0x20, 0x00, 0x00, 0x00, 0x00, 0x2F, 0xFF, 0xFB, 0x00, 0x00, 0x00, 0x00,
      36. 0x00, 0x00, 0x00, 0x1F, 0xFF, 0xFB, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0B, 0xFF, 0xFF, 0x20, 0x00, 0x00, 0x00,
      37. 0x00, 0x00, 0x00, 0x7F, 0xFF, 0xF6, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0xFF, 0xFF, 0x70, 0x00, 0x00, 0x00,
      38. 0x00, 0x00, 0x00, 0xCF, 0xFF, 0xF1, 0x00, 0x00, 0x00, 0x00, 0x00, 0x01, 0xFF, 0xFF, 0xD0, 0x00, 0x00, 0x00,
      39. 0x00, 0x00, 0x03, 0xFF, 0xFF, 0xA0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xAF, 0xFF, 0xF4, 0x00, 0x00, 0x00,
      40. 0x00, 0x00, 0x09, 0xFF, 0xFF, 0x50, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x5F, 0xFF, 0xFA, 0x00, 0x00, 0x00,
      41. 0x00, 0x00, 0x1E, 0xFF, 0xFE, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0E, 0xFF, 0xFF, 0x10, 0x00, 0x00,
      42. 0x00, 0x00, 0x6F, 0xFF, 0xFA, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0A, 0xFF, 0xFF, 0x60, 0x00, 0x00,
      43. 0x00, 0x00, 0xCF, 0xFF, 0xF4, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x04, 0xFF, 0xFF, 0xC0, 0x00, 0x00,
      44. 0x00, 0x03, 0xFF, 0xFF, 0xE0, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0xEF, 0xFF, 0xF3, 0x00, 0x00,
      45. 0x00, 0x09, 0xFF, 0xFF, 0x90, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x8F, 0xFF, 0xF9, 0x00, 0x00,
      46. 0x00, 0x0E, 0xFF, 0xFF, 0x30, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xFF, 0xFE, 0x00, 0x00,
      47. 0x00, 0x5F, 0xFF, 0xFD, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0D, 0xFF, 0xFF, 0x50, 0x00,
      48. 0x00, 0xBF, 0xFF, 0xF8, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x00, 0x08, 0xFF, 0xFF, 0xB0, 0x00,
      49. 0x02, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF2, 0x00,
      50. 0x08, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xF8, 0x00,
      51. 0x0E, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0x00,
      52. 0x4F, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0x40
      53. };
      54. GUI_CONST_STORAGE GUI_CHARINFO_EXT GUI_FontDelta_CharInfo[1] = {
      55. { 35, 37, -1, 11, 35, acGUI_FontDelta_0394 } /* code 0394, GREEK CAPITAL LETTER DELTA */
      56. };
      57. GUI_CONST_STORAGE GUI_FONT_PROP_EXT GUI_FontDelta_Prop1 = {
      58. 0x0394 /* first character */
      59. ,0x0394 /* last character */
      60. ,&GUI_FontDelta_CharInfo[ 0] /* address of first character */
      61. ,(GUI_CONST_STORAGE GUI_FONT_PROP_EXT *)0 /* pointer to next GUI_FONT_PROP_EXT */
      62. };
      63. GUI_CONST_STORAGE GUI_FONT GUI_FontDelta = {
      64. GUI_FONTTYPE_PROP_AA4_EXT /* type of font */
      65. ,60 /* height of font */
      66. ,60 /* space of font y */
      67. ,1 /* magnification x */
      68. ,1 /* magnification y */
      69. ,{&GUI_FontDelta_Prop1}
      70. ,48 /* Baseline */
      71. ,28 /* Height of lowercase characters */
      72. ,37 /* Height of capital characters */
      73. };
      74. /*********************************************************************
      75. *
      76. * Static code
      77. *
      78. **********************************************************************
      79. */
      80. /*********************************************************************
      81. *
      82. * Public code
      83. *
      84. **********************************************************************
      85. */
      86. /*********************************************************************
      87. *
      88. * MainTask
      89. */
      90. void MainTask(void) {
      91. GUI_Init();
      92. GUI_UC_SetEncodeUTF8();
      93. GUI_SetFont(&GUI_FontDelta);
      94. GUI_DispString("\xce\x94");
      95. while (1) {
      96. GUI_Delay(100);
      97. }
      98. }
      99. /*************************** End of file ****************************/
      I have created the code to Delta symbol for the font size 32 , i am running below code but i am not able to display the Delta symbol, Can you please help me , what is the problem with below code.
      #include "DIALOG.h"
      * Defines
      * Static data
      GUI_CONST_STORAGE unsigned char acGUI_FontDeltaa_0394[200] = { /* code 0394, GREEK CAPITAL LETTER DELTA */
      0xF0, 0x00, 0x00, 0x06, 0xFF, 0xF7, 0x00, 0x00, 0x00, 0xF0,
      0xF0, 0x00, 0x00, 0x0C, 0xF9, 0xFD, 0x00, 0x00, 0x00, 0xF0,
      0xF0, 0x00, 0x00, 0x3F, 0xE1, 0xEF, 0x30, 0x00, 0x00, 0xF0,
      0xF0, 0x00, 0x00, 0x8F, 0x90, 0x8F, 0x90, 0x00, 0x00, 0xF0,
      0xF0, 0x00, 0x00, 0xEF, 0x30, 0x2F, 0xE0, 0x00, 0x00, 0xF0,
      0xF0, 0x00, 0x05, 0xFB, 0x00, 0x0B, 0xF5, 0x00, 0x00, 0xF0,
      0xF0, 0x00, 0x0B, 0xF5, 0x00, 0x05, 0xFB, 0x00, 0x00, 0xF0,
      0xF0, 0x00, 0x2F, 0xE0, 0x00, 0x00, 0xEF, 0x20, 0x00, 0xF0,
      0xF0, 0x00, 0x7F, 0x80, 0x00, 0x00, 0x8F, 0x70, 0x00, 0xF0,
      0xF0, 0x00, 0xDF, 0x30, 0x00, 0x00, 0x3F, 0xD0, 0x00, 0xF0,
      0xF0, 0x04, 0xFC, 0x00, 0x00, 0x00, 0x0C, 0xF4, 0x00, 0xF0,
      0xF0, 0x09, 0xF6, 0x00, 0x00, 0x00, 0x06, 0xFA, 0x00, 0xF0,
      0xF0, 0x1F, 0xE1, 0x00, 0x00, 0x00, 0x01, 0xEF, 0x10, 0xF0,
      0xF0, 0x6F, 0x90, 0x00, 0x00, 0x00, 0x00, 0x9F, 0x60, 0xF0,
      0xF0, 0xCF, 0x30, 0x00, 0x00, 0x00, 0x00, 0x3F, 0xC0, 0xF0,
      0xF2, 0xFC, 0x00, 0x00, 0x00, 0x00, 0x00, 0x0C, 0xF3, 0xF0,
      0xF8, 0xF6, 0x00, 0x00, 0x00, 0x00, 0x00, 0x06, 0xF8, 0xF0,
      0xFE, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF, 0xFE, 0xF0,
      GUI_CONST_STORAGE GUI_CHARINFO_EXT GUI_FontDeltaa_CharInfo[1] = {
      { 19, 20, -1, 6, 18, acGUI_FontDeltaa_0394 } /* code 0394, GREEK CAPITAL LETTER DELTA */
      GUI_CONST_STORAGE GUI_FONT_PROP_EXT GUI_FontDeltaa_Prop135 = {
      0xFFFF /* first character */
      ,0xFFFF /* last character */
      ,&GUI_FontDeltaa_CharInfo[0] /* address of first character */
      GUI_CONST_STORAGE GUI_FONT GUI_FontDeltaa = {
      ,32 /* height of font */
      ,32 /* space of font y */
      ,{&GUI_FontDeltaa_Prop135}
      ,26 /* Baseline */
      ,15 /* Height of lowercase characters */
      ,20 /* Height of capital characters */
      * Static code
      * Public code
      * MainTask
      GUI_Init();
      GUI_SetColor(GUI_WHITE);
      GUI_SetFont(&GUI_FontDeltaa);
      while (1) {
      GUI_Delay(100);
      Try to change the following in GUI_FontDeltaa_CharInfo:
      1. 0x0394 /* first character */
      2. ,0x0394
      3. //0xFFFF /* first character */
      4. //,0xFFFF /* last character */
      If first and last character are 0xFFFF emWin will never find the character placed on 0x0394.
      Don't wonder why there is a frame around the Delta. This is becasue you are using the demo version of the FontConverter.
