[SOLVED] J-Link is low on memory
  • [SOLVED] J-Link is low on memory
    I am having some troubles with my J-Link BASE debugger. I am trying to use it as part of an automatic test suite, where I use the J-Link BASE to program a Nordic nRF52 board prior to running some tests. In this test suite, the J-Link BASE is used multiple times to re-program the board and get an SWO connection for debug logs.
    This typically works well the first few times, but after initiating and closing the connection a couple times, it stops working. Instead, I get this error with every attempt:
    1. ****** Error: The connected J-Link (S/N XXXXXXXX) is low on memory. Target connection cannot be established
    I can restore the J-Link by unplugging and replugging it. However, that is not much of a solution, since I need this to be automated.
    I have J-Link Software Pack 6.30e installed, with the debugger firmware updated. I'm using Windows 10. I have tried using both jlink.exe solely and arm-none-eabi-gdb + jlinkgdbservercl.exe in my scripts, and have the same problem.
    Do you have any idea of what causes this, and a way to avoid the problem? Or do you know some better way to restore the J-Link than replugging its USB cable?
    The post was edited 1 time, last by sfabian ().
  • Hello Fabian,
    Could you give us more information about your exact testing setup?
    How are you interfacing with J-Link, are you using the J-Link commander for that or the J-Link SDK?
    Could you provide a J-Link log file of such a session?
    It sounds like the J-Link connection is not closed properly and after a couple of runs the internal buffer is full.
    I am using J-Link to download software and get debug logs as part of a test automation system in Robot Framework/Python. As such, I have a Python script which in turn starts J-Link and other applications. I have tried two approaches, both which give me the same error.
    For the first approach, Python starts J-Link Commander with the following command:
    1. jlink -device nRF52832_xxAA -If SWD -Speed 4000 -autoconnect 1 -commanderscript {commander_script_path}
    The commander script contains the following commands:
    1. h
    2. loadfile {binary_path}
    3. r
    4. go
    5. swoview {swo_freq}
    The command is started using Python's subprocess.Popen(), and the process is killed when the test suite is finished.
    For the other approach I use arm-none-eabi-gdb + J-Link GDB Server CL + Telnet. Here, I first start J-Link GDB Server CL with the following command:
    1. JLinkGDBServerCL -select USB -device {cpu_type} -if SWD -speed 1000 -ir -singlerun -vd -strict -nogui -timeout 0
    I then start arm-none-eabi-gdb with the following command:
    1. arm-none-eabi-gdb --eval-command='set $swo_cpu_speed = {swo_cpu_speed}' --eval-command='set $should_run = {should_run}' --command={gdb_commands_path} {binary_path}
    The GDB commands file contains this:
    1. set mem inaccessible-by-default off
    2. target remote localhost:2331
    3. monitor speed 1000
    4. monitor clrbp
    5. monitor reset
    6. monitor halt
    7. monitor regs
    8. flushreg
    9. monitor speed auto
    10. monitor flash breakpoints 1
    11. monitor semihosting enable
    12. monitor semihosting IOClient 1
    13. monitor SWO DisableTarget 0xFFFFFFFF
    14. eval "monitor SWO EnableTarget %u 0 0x1 0", $swo_cpu_speed
    15. load
    16. monitor clrbp
    17. monitor reset
    18. monitor halt
    19. monitor regs
    20. flushreg
    21. if $should_run
    22. continue
    23. else
    24. quit
    25. end
    These processes are also started using Python's subprocess.Popen(). Finally, I start Telnet using Python's telnetlib. When the test suite is over, I kill the processes using process.kill().
    Perhaps the process killing in Python is not nice enough to close J-Link properly?
    Do you think there is a better way to do this? I have not really looked into the SDK. Is it easy to achieve what I want through Python using the SDK?
    I have run my script with the second approach adding a '-log' parameter to the GDB Server command. I'm attaching the log outputs: both from a successful attempt and from a subsequent failed attempt.
    (I omitted some lines from the successful attempt's log, since I guessed that they were actually the binary I'm downloading... Perhaps I'm overly paranoid, but I prefer to be on the safe side.)
    Thank you very much for taking your time to help me!
  • Hello Fabian,
    This sounds much like the scenario I described in my last post. All IDEs, Tools etc. that interface with J-Link need to issue J-Link a close command before terminating the main application. Otherwise the behaviour can be unpredictable.
    The SDK will offer you a documentation with all J-Link API functions and multiple example projects so you can create an application that fits your testing needs perfectly.
    All our software tools like Ozone, J-Link Commander, J-LinkGDBServer etc.etc. all use the SDK as base and can be recreated using the J-Link SDK.
    More information can be found here: segger.com/products/debug-prob…nk/technology/j-link-sdk/
    Thank you very much for your help. I have now found a solution.
    I have realized that there is no easy way to gracefully terminate a subprocess in Python in Windows. It is possible, but it would require a bunch of extra wrapping code. If anyone is interested to learn more, check this link.
    Instead, I did as you recommended, and used the SDK. Well, I didn't use the SDK directly, but I found the excellent Python library pylink, which in turn uses the SDK. The pylink library allows me to easily close the J-Link connection in a graceful manner.
  • Hello Fabian,
