[SOLVED] Download to EFM32 Happy Gecko Dev Kit fails
  • [SOLVED] Download to EFM32 Happy Gecko Dev Kit fails
    Hi
    I'm currently evaluating Embedded Studio and embOS Trial from here: segger.com/evaluate-our-softwa…abs/efm32-happy-gecko-dk/
    Target is stock EFM32HG Dev Kit.
    Unmodified project loads and builds fine but fails to download to target. I've tried projects 'Hello world' and 'Start_EFM32HG322' with the same result.
    Preparing target for download
    Loading target script file EFM32HGxxx_Target.js
    Executing script Reset();
    Downloading ‘Hello World.elf’ to J-Link
    Programming 3.5 KB of addresses 00000000 — 00000e4f
    Programming 0.0 KB of addresses 00000e50 — 00000e5b
    Timeout while preparing target, RAMCode did not respond in time. (PC = 0x00000000, CPSR = 0x00000000, LR = 0x01000003)!
    Failed to prepare RAMCode using RAM
    I have verified that download works fine with Simplicity Studio. I didn't check with IAR yet. Also debugger connection seems to work, it's just that target download doesn't.
    Any ideas what might be wrong? I would expect that "it simply works" -- no tweaking or configuration needed.
    Juho
  • Hello Juho,
    Embedded Studio 3.34a was shipped with J-Link DLL V6.30e.
    With that DLL version SiLabs asked us to add a new feature. Unfortunately it seems that we got incorrect information from SiLabs so the feature was implemented for some devices that don't support it as well.
    This will of course be fixed with our next J-Link software version expected to be released by the end of the week.
    As a current workaround we recommend downgrading the DLL in the Embedded Studio install folder by J-Link DLL V6.30d.
    Simply overwrite the DLL in the ES install folder by the older DLL version and everything should be working again as expected.
  • Hi Juho,
    Great to hear that the workaround is working for you.
