[SOLVED] mkld -verbose is not verbose ..
  • [SOLVED] mkld -verbose is not verbose ..
    It would help if mkld -verbose would actually print something of use if it fails to parse xml files.
    With, or without -verbose, if say a memory map file parsing fails, it only prints
    error: cannot load memory map file
    mkld is an internal tool and is not verbose.
    Usually it is only used by ES internally so verbose option is not necessary.
