[SOLVED] J-Scope: saving manual channel layout in config
  • [SOLVED] J-Scope: saving manual channel layout in config
    in J-Scope I'm missing the feature that the manually set layout of the traces is saved in the config file, too.
    At start, Y Resolution and Offset is scaled automatically according to the data, which generally helps, but I'd like to store my manual settings for the Y Res. and Offset, too. E.g. if something crashes I have to manually restore the settings every time.
    Is there a way to make this easier?
    Thanks!
  • Yes, I tested 5.10d and 6.11j.
    YOffset="..." and YResolution="..." are stored and initially restored on opening an exisiting project, as you wrote. But the problem is that the channels get autoscaled and Y-shifted again when I start sampling and my manual settings are not respected any more.
    I manually set the parameter IsAutoConfig="0" for all channels in the config file, but this does not help.
    Maybe the question has to be rephrased: Is it possible to turn off autoscaling?
  • Hi, thanks for your reply. I retested and attached the files:
    Setup: Win7Prof in Virtualbox on Fedora host, J-Link Edu, no issues with J-Scope or debugging
    Steps done:
    1) Created new project in J-Scope 6.11j.
    2) Started sampling, Y resolution and offset was adjusted automatically.
    3) Set Y resolution and Y offset, both for every channel, in the GUI, saved config to Test_01.jscope. (renamed later to Test_01.jscope.txt for upload)
    4) Closed J-Scope.
    5) Started J-Scope and loaded Test_01.jscope. The Y settings are as I set them manually before, see Test_01_opened.png.
    6) Started sampling, target is generating data.
    7) As soon as data comes in, J-Scope autoscales, see Test_01_StartedSampling.png
    It does not matter if first sampling in J-Scope is started and then the target starts sending data or vice versa, the behaviour is the same.
    using RTT the channels are reset to default values on every start of a sampling session.
    I tried using HSS, which behaves different and keeps the scaling values for future sessions.
    I will put this on the feature request list, currently there is no way to keep the scaling values for RTT sessions.
    Arne
