[ABANDONED] GDB behaving abnormally (won't stop at breakpoints)
  • [ABANDONED] GDB behaving abnormally (won't stop at breakpoints)
    Hello all,
    I've been developing some application for quite a while and I now went into a weird error.
    Description of the development:
    • MK22FN512VLH12 (custom board)
    • FreeRTOS 9.0.0, custom heap from here: nadler.com/embedded/newlibAndFreeRTOS.html
    • newlib (no semihosting)
    • SEGGER RTT
    • Debuger "Other Options" contains: "-s -rtos GDBServer/RTOSPlugin_FreeRTOS" (everything else is pretty standard)
    • J-Link Plus Debug tool
    • J-Link Software version 6.30e
    • IDE KDS 3.2.0
    • GCC toolchain version 6 Q2 2017
    • The exact same problem happened with a FRDM-K82F dev board, another FreeRTOS 9.0.0 based firmware, using MCUXpresso 10.1.1 and some older version of the J-Link software
    It was all working correctly until I added some more code (yes, I know it probably have something to do with it, nevertheless this behavior is not expected), I could add breakpoints throughout the code, execute instructions step by step wherever I wanted. After adding this piece of code, I can step into the code until the first xTaskCreate. To be more specific, the exact point where things go wrong is inside the function prvAddNewTaskToReadyList(), instruction pxCurrentTCB = pxNewTCB;. If I step into this function (should stop at the next instruction), the firmware starts executing as if I pressed Resume, I can still pause the software and it kind of works. If I add any breakpoints to try to stop the FW after the mentioned instruction, the debug section breaks and I get the following messages on the terminal "[GDB SEGGER J-Link Debugging] JLinkGDBServerCL":
    ...Breakpoint reached @ address 0x00015290 ///----------------------------------------that's the breakpoint on the start of main()
    Reading all registers
    Read 4 bytes @ address 0x00015290 (Data = 0xFA63F00B)
    Removing breakpoint @ address 0x00015290, Size = 2
    Removing breakpoint @ address 0x0001989C, Size = 2
    Removing breakpoint @ address 0x000198C6, Size = 2
    Setting breakpoint @ address 0x0001989C, Size = 2, BPHandle = 0x0004
    Setting breakpoint @ address 0x000198C6, Size = 2, BPHandle = 0x0005
    Performing single step...
    ...Breakpoint reached @ address 0x0002075A
    Read 4 bytes @ address 0x0002075A (Data = 0xAF00B580)
    Setting breakpoint @ address 0x00015290, Size = 2, BPHandle = 0x0006
    Starting target CPU...
    ...Breakpoint reached @ address 0x0001989C
    Read 4 bytes @ address 0x00000000 (Data = 0x1FFFD1A0)
    The last 4 lines keep repeating forever and I can't pause the debugger. If I click Stop, it takes a long time and gives me an error message "Connection Shut Down" (but eventually stops).
    I tried the same process using the j-Trace Pro and got the same results.
    Any ideas?
    Bruno
