[SOLVED] [Ozone] Forced halt in SVC vector
  • [SOLVED] [Ozone] Forced halt in SVC vector
    I am currently using:
    - Ozone 2.56c on Linux with the JLink DLLs 6.30d;
    - TMS570LC4357 on the XL2-570LC43(A) development board;
    - JTAG @1 MHz with semihosting Off and RTT Off;
    - No custom JLink scripts;
    I have an issue where from time to time I am having problems whenever the ARM assembly "SVC #" instruction is called. Whenever I reset and continue, Ozone will break at 0x08 (ARM SVC vector) even if I didn't put a breakpoint there.
    I've read that Semihosting uses the SVC location in order to work. I've tried to enable/disabling semihosting and reconfigure semihosting to use another memory location with "Project.SetSemihosting" and "Project.ConfigSemihosting" without any change.
    I've also tried:
    - Using JLink DLLs 6.30e
    - Changing JTAG speed
    - Adding/removing breakpoints
    - Disconnect, Reconnect to target
    - Using Windows
    If I continuosly reset and continue I eventually manage to continue,sometimes, without breaking at the SVC, but it's rather rare.
    I've produced a simple assembly example where I just use the SVC assembly instruction and NOPs in TI Code Composer Studio. I've attached Code Composer Studio project files, Ozone project files and the binary to this thread.
    As a note, the problem doesn't subsist if I use the embedded TI XDS110 debugger present on board.
    Could you please point me in the right direction on why this happens and how I can fix it?
    Thanks in advance!
    Alessandro
    • svc_example.zip
      (22.84 kB, downloaded 546 times, last: )
  • Hello Alessandro,
    Thank you for providing the example project.
    The issue was reproducible and we are currently working on a fix for this.
  • Hello Alessandro,
