display hang
    • display hang
      hi, i had created one editbox as child window, and displaying some float value. after 5 minutes controller get hang what would be the issue?[/size]
      #include "main.h"
      #define EDIT_MAX_LEN 200
      #define EDIT_ALIGN (GUI_TA_HCENTER | GUI_TA_VCENTER)
      #define RADIUS 10
      #define BORDER 4
      * _OnPaint
      static void _OnPaint(EDIT_Handle hEdit) {
      GUI_RECT Rect = {0};
      char acText[EDIT_MAX_LEN + 1];
      GUI_COLOR Color;
      const GUI_FONT * pFont;
      GUI_COLOR BkColor;
      int MaxLen;
      Rect.x1 = WM_GetWindowSizeX(hEdit) - 1;
      Rect.y1 = WM_GetWindowSizeY(hEdit) - 1;
      BkColor = EDIT_GetBkColor(hEdit, 0);
      GUI_SetColor(BkColor);
      GUI_FillRoundedRect(Rect.x0, Rect.y0, Rect.x1, Rect.y1, RADIUS);
      MaxLen = EDIT_GetNumChars(hEdit) + 1;
      if (MaxLen) {
      pFont = EDIT_GetFont(hEdit);
      EDIT_GetText(hEdit, acText, MaxLen);
      Color = EDIT_GetTextColor(hEdit, 0);
      GUI_SetColor(Color);
      GUI_SetBkColor(BkColor);
      Rect.x0 = BORDER;
      Rect.y0 = BORDER;
      Rect.x1 -= BORDER;
      Rect.y1 -= BORDER;
      GUI_SetFont(pFont);
      GUI_DispStringInRectWrap(acText, &Rect, EDIT_ALIGN, GUI_WRAPMODE_WORD);
      * _cbEdit
      static void _cbEdit(WM_MESSAGE * pMsg) {
      switch (pMsg->MsgId) {
      case WM_CREATE:
      EDIT_SetTextAlign(pMsg->hWin, EDIT_ALIGN);
      break;
      case WM_PAINT:
      _OnPaint(pMsg->hWin);
      break;
      default:
      EDIT_Callback(pMsg);
      break;
      * MainTask
      void vGeneralFunction_StartTest(void) {
      WM_HWIN hWin;
      GUI_Init();
      hWin = EDIT_CreateAsChild(10, 10, 400, 150, WM_HBKWIN, 2, WM_CF_SHOW, EDIT_MAX_LEN);
      WM_SetHasTrans(hWin);
      WM_SetCallback(hWin, _cbEdit);
      EDIT_SetFont (hWin, &GUI_FontArial100);
      EDIT_SetText (hWin, "Hello");
      while (1) {
      if (Flag500ms==SET){
      fValue = fValue + 0.5;
      vGeneralFunction_FloatToString(fValue, &strGen[0], 2);
      EDIT_SetText (hWin, strGen);
      Flag500ms = RESET;
      GUI_Delay(25);
      /*************************** End of file ****************************/
      I can't say what causes this issue. I gave it a try and let run your code (except vGeneralFunction_FloatToString()) but it is running without any problems.
      Did you implemented the functions GUI_X_Delay() and GUI_X_GetTime() properly?
      GUI_X_GetTime() should return a timer variable which gets incremented each millisecond. You can set up either a hardware timer (or SystickTimer on Cortex M) or use the timer API of an operating system.
      GUI_X_Delay() should wait for the given time in milliseconds.
      If GUI_X_GetTime() is not implemented correctly emWin can hang in GUI_Delay() waiting for ever...
