[SOLVED] J-Link cannot connect to i.MX6ULL target
  • [SOLVED] J-Link cannot connect to i.MX6ULL target
    I just started i.MX6ULL development using J-Link PLUS Compact and IMX6ULLEVK board.
    But I cannot connect to target.
    According to the link https://wiki.segger.com/IMX6ULL-EVK,
    I removed the mentioned resistors on IMX6ULLEVK board.
    J-link commander runs on Windows10 64bit.
    The commander's log :
    SEGGER J-Link Commander V6.30d (Compiled Feb 16 2018 13:30:47)
    DLL version V6.30d, compiled Feb 16 2018 13:30:32
    Firmware: J-Link V10 compiled Feb 16 2018 13:03:54
    Hardware version: V10.10
    S/N: 850100110
    VTref = 3.322V
    J-Link>con
    Please specify device / core. <Default>: CORTEX-A7
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    S) SWD
    TIF>
    Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
    JTAGConf>
    Speed>2000
    Device "CORTEX-A7" selected.
    Connecting to target via JTAG
    TotalIRLen = 13, IRPrint = 0x0101
    WARNING: At least one of the connected devices is not JTAG compliant (IEEE Std 1149.1, 7.1.1.d, IR-cells). (NumDevices = 3, NumBitsSet = 2)
    JTAG chain detection found 3 devices:
    #0 Id: 0x5BA00477, IRLen: 04, CoreSight JTAG-DP
    #1 Id: 0x00000001, IRLen: 05, Unknown device
    #2 Id: 0x088C101D, IRLen: 04, JTAG-DP
    AP[2]: Stopped AP scan as end of AP map seems to be reached
    AP[0]: AHB-AP (IDR: 0x74770001)
    AP[1]: APB-AP (IDR: 0x44770002)
    AP[0]: Skipped. Not an APB-AP
    AP[1]: APB-AP found
    Invalid ROM table component ID 0x2F0F0F02 @ 0x20001EF0 (expected 0xB105100D). Trying again at alternative offset.
    Invalid ROM table component ID 0x2F0F0F02 @ 0x60000FF0 (expected 0xB105100D). Trying again at alternative offset.
    ****** Error: Cortex-A/R-JTAG (connect): Could not determine address of core debug registers. Incorrect CoreSight ROM table in device?
    Cannot connect to target.
    I've read the similar thread.
    [SOLVED] J-Link commander cannot connect to i.MX6UL target
    I'm using newer version software package, but encountered similar phenomenon.
    Would you please advice me the solution.
    Thank you very much in advance.
    Keishi
    The post was edited 2 times, last by keishi ().
  • Hello Keishi,
    You need to specify the exact device name.
    Currently you are trying to connect to a generic Cortex-A7 device which will not work.
    When Commander asks you for the device name you can either type "?" to get a list of supported devices or write it directly.
    The correct device names for imx devices can be found here: wiki.segger.com/IMX_Series_Devices
  • Hello Keishi,
    We will consider this case as closed now.
