[SOLVED] STM32F411RE - Timeout while checking target RAM
  • [SOLVED] STM32F411RE - Timeout while checking target RAM
    I'm trying to flash STM32F411RE using J-Track for ARM Cortex-M, it seems that the flasher connects fine to the device but when I try to erase or loadbin the "Timeout while checking target RAM" error occurs. Is there something with my flashing process, please?
    Log from JLinkExe is attached below.
    ----- Update -----
    And we were able to flash this uC using ST-Link flasher.
    Kind Regards,
    Krzysztof
    $ JLinkExe -device STM32F411RE -speed 4000 -if SWD
    SEGGER J-Link Commander V6.20d (Compiled Sep 29 2017 16:44:27)
    DLL version V6.20d, compiled Sep 29 2017 16:44:18
    Firmware: J-Trace PRO V1 Cortex-M compiled Dec 1 2017 14:41:37
    Hardware version: V1.00
    S/N: 751000106
    IP-Addr: 192.168.0.2
    Emulator has RAWTRACE capability
    VTref = 3.305V
    J-Link>connect
    Device "STM32F411RE" selected.
    Connecting to target via SWD
    AP[0]: Core found
    CoreSight components:
    ROMTbl[0] @ E00FF000
    ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS
    ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 003BB001 ITM
    ROMTbl[0][4]: E0040000, CID: B105900D, PID: 000BB9A1 TPIU
    ROMTbl[0][5]: E0041000, CID: B105900D, PID: 000BB925 ETM
    Cortex-M4 identified.
    J-Link>erase
    Erasing device (STM32F411RE)...
    ****** Error: Timeout while checking target RAM, RAMCode did not respond in time. (PC = 0x00000000, CPSR = 0x00000000, LR = 0x21000000)!
    Failed to prepare for programming.
    Failed to execute RAMCode for RAM check!
    ERROR: Erase returned with error code -1."
    The post was edited 1 time, last by krzysztof.rosinski ().
    You seem to be using an older J-Link software version.
    Could you update to the latest version and check if the behaviour improves?
    Additionally, could you try to reset the target after a connect int J-Link commander before calling loadbin. Does that make a difference?
  • Hello Nino,
    This looks exactly the same with the newest J-Link (V6.30c) and reset before erase / loadbin.
    Krzysztof
    SEGGER J-Link Commander V6.30c (Compiled Feb 9 2018 17:21:42)
    DLL version V6.30c, compiled Feb 9 2018 17:21:32
    Firmware: J-Trace PRO V1 Cortex-M compiled Feb 2 2018 18:26:42
    S/N: 751000106
    VTref = 3.303V
    J-Link>connect
    AP[0]: Core found
    ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 000BB00C SCS-M7
    J-Link>r
    Reset delay: 0 ms
    J-Link>erase
    ****** Error: Timeout while checking target RAM, RAMCode did not respond in time. (PC = 0x00000000, CPSR = 0x00000000, LR = 0x21000003)!
  • Hello Krzysztof,
    Thank you for providing the log.
    We tried to replicate your setup with a NUCLEO-F411RE board and a J-Trace PRO as debug probe and everything is working as expected. See attachment.
  • Hello Krzysztof,
    Try connecting the reset pin as well to J-Link.
    Generally it is recommended to connect the reset Pin to J-Link to have a fallback if software reset is not enough on the used target device.
    If it still does not work compare the eval board schematic with your custom board schematic and see if there are any other differences.
  • Hello Krzysztof,
    Great to hear that you are up and running.
    We will consider this case as closed now.
