[SOLVED] Specifying include path using SES folder
  • [SOLVED] Specifying include path using SES folder
    It would be nice if you could specify include path using the SES folder you create. Which then magically resolves to correct include path (or paths, depending on folder) when building.
    It would be nice to be able to reference file (=folder) path using the dynamic macros.
    E.g. create SES folder "my_folder", which may map to some folder on file system.
    And then if you could use a marco such as $(my_folder) which resolves to correct file system path(s).
    This is currently not possible.
    We will add this to the wish list. A similar implementation was already planned so we will see how we can accompany this request as well.
