[SOLVED] Setting build options per file
    You can set build options for each file individually under option External Build-> C Compile Command for example for C files.
    On folder level this is not possible currently but might be added in future.
    yes you can, picture attached.
    Simply right click the file you want to set the option for and select Edit Options...
    Great to hear that it is working for you as well.
