[SOLVED] Setting build options per file
  • [SOLVED] Setting build options per file
    It seems not possible to set build options / compile options per-file ?
    It doesn't even seem possible to set it per folder - either dynamic or not.
    (I feel this is a disadvantage relative to Eclipse).
    You can set build options for each file individually under option External Build-> C Compile Command for example for C files.
    On folder level this is not possible currently but might be added in future.
    yes you can, picture attached.
    Simply right click the file you want to set the option for and select Edit Options...
    Great to hear that it is working for you as well.
    We will consider this thread as closed now.
