[SOLVED] Add Newline to End of File
  • [SOLVED] Add Newline to End of File
    I want to utilize the Formatter built into SES. The only issue is it removes the newline at the end of the files. I have tried looking through the Text Editor Settings to insert (or not remove) the newline. I have not yet found the option.
    Do you know of a way to accomplish this?
    Michael
    This is currently not available as an option.
    We will most likely add this per default that new lines at the end of files will be kept.
    This will most likely be implemented with the next Embedded Studio release.
