[SOLVED] systemview systemview-2.52.1.x86_64.rpm is a broken install
  • [SOLVED] systemview systemview-2.52.1.x86_64.rpm is a broken install
    After (successfully) installing systemview-2.52.1.x86_64.rpm, application won't run because:
    SystemView: error while loading shared libraries: libQtGui.so.4: cannot open shared object file: No such file or directory
    (This library seems included in JLink & ozone installation packages, unlike ..)
    The post was edited 1 time, last by v01d ().
    We tried to replicate the described behaviour in a Fedora 27 VM.
    First we installed the J-Link software RPM package, then SystemView.
    After that SystemView could be launched over CL or per double click without any issues.
    Picture is attached.
    Could you describe step by step how you installed the software and in what order?
    As far as I see in my original install log:
    1 JLink_Linux_V630a_x86_64.rpm
    2 ozone-2.54.2.x86_64.rpm
    3 JLink_Linux_V630b_x86_64.rpm ozone-2.56.x86_64.rpm systemview-2.52.1.x86_64.rpm
    Can I ask, how is systemview suppose to run if it does not include it's own Qt libraries, and the host system may or not have them?
    As RPM does not spec that dependency.
    Could you paste the output of ldd SystemView?
    We are currently working on a Linux white list for Linux distributions that fulfill the needed requirements.
    1. ldd '/opt/SEGGER/SystemView/SystemView'
    2. linux-vdso.so.1 (0x00007ffd30ffc000)
    3. libQtGui.so.4 => /lib64/libQtGui.so.4 (0x00007fca5de9d000)
    4. libQtCore.so.4 => /lib64/libQtCore.so.4 (0x00007fca5d999000)
    5. libpthread.so.0 => /lib64/libpthread.so.0 (0x00007fca5d77a000)
    6. libstdc++.so.6 => /lib64/libstdc++.so.6 (0x00007fca5d3f4000)
    7. libm.so.6 => /lib64/libm.so.6 (0x00007fca5d09f000)
    8. libgcc_s.so.1 => /lib64/libgcc_s.so.1 (0x00007fca5ce88000)
    9. libc.so.6 => /lib64/libc.so.6 (0x00007fca5caa5000)
    10. librt.so.1 => /lib64/librt.so.1 (0x00007fca5c89d000)
    11. libdl.so.2 => /lib64/libdl.so.2 (0x00007fca5c699000)
    12. libgthread-2.0.so.0 => /lib64/libgthread-2.0.so.0 (0x00007fca5c497000)
    13. libglib-2.0.so.0 => /lib64/libglib-2.0.so.0 (0x00007fca5c183000)
    14. libpng16.so.16 => /lib64/libpng16.so.16 (0x00007fca5bf50000)
    15. libz.so.1 => /lib64/libz.so.1 (0x00007fca5bd39000)
    16. libfreetype.so.6 => /lib64/libfreetype.so.6 (0x00007fca5ba84000)
    17. libgobject-2.0.so.0 => /lib64/libgobject-2.0.so.0 (0x00007fca5b831000)
    18. libSM.so.6 => /lib64/libSM.so.6 (0x00007fca5b629000)
    19. libICE.so.6 => /lib64/libICE.so.6 (0x00007fca5b40d000)
    20. libXi.so.6 => /lib64/libXi.so.6 (0x00007fca5b1fc000)
    21. libXrender.so.1 => /lib64/libXrender.so.1 (0x00007fca5aff2000)
    22. libXrandr.so.2 => /lib64/libXrandr.so.2 (0x00007fca5ade7000)
    23. libXfixes.so.3 => /lib64/libXfixes.so.3 (0x00007fca5abe1000)
    24. libXcursor.so.1 => /lib64/libXcursor.so.1 (0x00007fca5a9d6000)
    25. libXinerama.so.1 => /lib64/libXinerama.so.1 (0x00007fca5a7d3000)
    26. libfontconfig.so.1 => /lib64/libfontconfig.so.1 (0x00007fca5a58e000)
    27. libXext.so.6 => /lib64/libXext.so.6 (0x00007fca5a37c000)
    28. libX11.so.6 => /lib64/libX11.so.6 (0x00007fca5a03e000)
    29. /lib64/ld-linux-x86-64.so.2 (0x00007fca5ebc4000)
    30. libpcre.so.1 => /lib64/libpcre.so.1 (0x00007fca59dcb000)
    31. libbz2.so.1 => /lib64/libbz2.so.1 (0x00007fca59bba000)
    32. libffi.so.6 => /lib64/libffi.so.6 (0x00007fca599b2000)
    33. libuuid.so.1 => /lib64/libuuid.so.1 (0x00007fca597ad000)
    34. libexpat.so.1 => /lib64/libexpat.so.1 (0x00007fca5957b000)
    35. libxcb.so.1 => /lib64/libxcb.so.1 (0x00007fca59353000)
    36. libXau.so.6 => /lib64/libXau.so.6 (0x00007fca5914f000)
  • Hi Nino,
    Thanks for that list. Coupled with the other discussion we had under J-Link forum, my thread on incomplete RPM spec, this issue is exhausted now and can be closed.
    I still believe Segger needs to fix the RPM specs, so that packages can actually be installed correctly out-the-box.
    Thank you for your feedback.
    We will consider this case as solved now.
