STM32H7 GUI_MULTIBUF and screen tearing...
    • STM32H7 GUI_MULTIBUF and screen tearing...
      I am seeing a case where GUI_DrawBitmapEx() does not seem to behave properly within
      GUI_MULTIBUF_Begin()/End(), specifically:
      WM_MULTIBUF_Enable(1);
      GUI_MULTIBUF_Begin();
      GUI_DrawBitmapEx(&bmminus1, 285, 300, 0, 0, 300, 300); // Tearing occurs at this line
      GUI_MULTIBUF_End();
      GUI_Exec();
      I would expect to see no change to the display during the Begin()/End().
      When I run or single-step through the DrawBitmap, the screen tears...
    • RE: STM32H7 GUI_MULTIBUF and screen tearing...
      Thanks for the reply...
      I tried to disable/enable interrupts and it still tears...
      I was able to fix it by adding the following line during initialization:
      GUI_MULTIBUF_Config(3);
      Although it sure seems like a bug in the emWin code that anything
      within a GUI_MULTIBUF_Begin()/End() shouldn't cause a change on the screen.
      are you using the sample LCDConf.c provided by STM?
      On the first look it should work.
      1. GUI_MULTIBUF_Begin();
      2. GUI_DrawBitmapEx(&bmminus1, 285, 300, 0, 0, 300, 300); // Tearing occurs at this line
      3. GUI_MULTIBUF_End();
      With the code above the bitmap should appear after GUI_MULTIBUF_End().
      Where a do you call this code?
      If you call it from within a WM_PAINT case of a window callback there is no need to call any multi buffering API. Just call WM_MULTIBUF_Enable(1) before creating the first window and the window manager will take care about starting and ending (switching back and front buffers) of multi buffering.
