Selectively activate MEMDEV for each window
    • Selectively activate MEMDEV for each window
      Hi all,
      I have an application that is made of several dialogs.
      My system is STM32F103VET based and connected via FSMC controller / 8080 interface to a 480x272 display, 565 color depth.
      I want to activate MEMDEV for some windows and not on others in order to prevent slow windows update.
      Consider the first dialog created at application start:
      1. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
      2. { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 480, 272, WM_CF_MEMDEV_ON_REDRAW, 0x0, 0 },
      3. { PROGBAR_CreateIndirect, NULL, ID_PROGBAR_0, 10, 200, 460, 45, PROGBAR_CF_HORIZONTAL, 0x0, 0},
      4. { BUTTON_CreateIndirect, NULL, ID_BUTTON_0, 435, 1, 40, 33, 0, 0x0, 0}
      5. };
      Here the MEMDEV is correctly activated for this dialog
      Now, if I create a new dialog with the same function parameter:
      2. { WINDOW_CreateIndirect, NULL, ID_WINDOW_0, 0, 0, 480, 272, WM_CF_MEMDEV, 0x0, 0},
      3. { LISTWHEEL_CreateIndirect, NULL, ID_LISTWHEEL_0, 86, 70, 30, 93, 0, 0x0, 0 },
      4. { LISTWHEEL_CreateIndirect, NULL, ID_LISTWHEEL_1, 121, 70, 30, 93, 0, 0x0, 0 },
      5. { LISTWHEEL_CreateIndirect, NULL, ID_LISTWHEEL_2, 176, 70, 30, 93, 0, 0x0, 0 },
      6. { LISTWHEEL_CreateIndirect, NULL, ID_LISTWHEEL_3, 210, 70, 100, 93, 0, 0x0, 0 },
      7. { LISTWHEEL_CreateIndirect, NULL, ID_LISTWHEEL_4, 316, 70, 60, 93, 0, 0x0, 0 },
      8. { BUTTON_CreateIndirect, "SAVE", ID_BUTTON_SAVE, 165, 190, 60, 60, 0, 0x0, 0 },
      9. { BUTTON_CreateIndirect, "CANCEL", ID_BUTTON_CANCEL, 245, 190, 60, 60, 0, 0x0, 0 },
      10. };
      Memdev is not activate in this new dialog.
      But if I set the global flag at initialisation:
      1. void GUITask(void const* argument)
      2. {
      3. WM_SetCreateFlags(WM_CF_MEMDEV);
      4. GUI_Init();
      5. FT5206_Init();
      6. (...)
      It correctly works for all windows and dialogs, so I suppose it is not a memory issue, I also tried to increase the memory allocated for GUI and nothing changes.
      But I do not want MEMDEV on all dialogs.
      What can I do?
      In the second _aDialogCreate structure you have enabled automatic use of memory devices only for the 'root' window but not for the child windows.
      You have to set the WM_CF_MEMDEV_ flag for all windows you want to use memory devices. Like this:
      2. { WINDOW_CreateIndirect, NULL, ID_WINDOW_0, 0, 0, 480, 272, WM_CF_MEMDEV, 0x0, 0}, // This window will use memory devices
      7. { LISTWHEEL_CreateIndirect, NULL, ID_LISTWHEEL_4, 316, 70, 60, 93, WM_CF_MEMDEV, 0x0, 0 }, // This window will also use memory devices
      10. };
      With the struct above, only the 'root' window and the fifth LISTWHEEL will use memory devices.
