GRAPH SetPenSize Problem
    • GRAPH SetPenSize Problem
      hello
      I created a GRAPH with GUIBuilder and use it.
      GRAPH work fine and show attach Data.
      but when i use GRAPH_DATA_XY_SetPenSize() to change pen size the size off pen not change.
      WM_HWIN MainTask(void) {
      WM_HWIN hWin;
      WM_HWIN hItem;
      GRAPH_DATA_Handle hData1;
      hWin = GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
      hGraph = WM_GetDialogItem(hWin, ID_GRAPH_0);
      hData1 = GRAPH_DATA_YT_Create(GUI_BLUE, 500, 0, 0);
      GRAPH_DATA_YT_SetAlign(hData1, GRAPH_ALIGN_LEFT);
      GRAPH_DATA_XY_SetLineStyle( hData1, GUI_LS_SOLID);
      GRAPH_DATA_XY_SetPenSize(hData1, 5);
      GRAPH_AttachData(hGraph, hData1);
      The post was edited 6 times, last by mahdi ().
      The function GRAPH_XY_SetPenSize() is only for setting the pensize of a XY-graph. You have created a YT-graph and can't use the XY related functions.
      Unfortunately, there is no way to adapt the pensize for a YT-graph.
      In this case you could try to set a user draw function with GRAPH_SetUserDraw() or create your own graph with function the GUI_DrawGraph().
