[SOLVED] pxa255: CPU-TAP not found in JTAG chain
  • [SOLVED] pxa255: CPU-TAP not found in JTAG chain
    Hallo,
    ich versuche die Verbindung mit einem PXA255 aufzubauen. Leider erhalte ich immer folgenden Fehler.
    SEGGER J-Link Commander V6.22a (Compiled Nov 28 2017 17:56:48)
    DLL version V6.22a, compiled Nov 28 2017 17:56:10
    Firmware: J-Link V10 compiled Nov 28 2017 11:45:53
    Hardware version: V10.10
    S/N: 260104941
    License(s): FlashBP, GDB
    OEM: SEGGER-EDU
    VTref = 3.264V
    J-Link>connect
    Please specify device / core. <Default>: ARM7
    Type '?' for selection dialog
    Device>
    J) JTAG (Default)
    TIF>j
    Device position in JTAG chain (IRPre,DRPre) <Default>: -1,-1 => Auto-detect
    JTAGConf>
    Speed>
    Device "ARM7" selected.
    Connecting to target via JTAG
    TotalIRLen = 5, IRPrint = 0x01
    JTAG chain detection found 1 devices:
    #0 Id: 0x69264013, IRLen: 05, Unknown device
    ****** Error: CPU-TAP not found in JTAG chain
    Cannot connect to target.
    Ebenso mit dem Sample-Projekt für den JFlasher (irgendwo hier im Forum gefunden).
    Eigentlich scheint er ja die CPU zu erkennen oder nicht? Die ID stimmt mal mit der aus dem JFlasher Projekt überein
    Vielen Dank
    Please keep your posts in English if possible (first forum rule).
    Regarding the PX255 device, it is currently not supported by J-Link: segger.com/downloads/supported-devices.php
    Following the thread you are referring to it did not work back then as well: forum.segger.com/index.php?pag…ighlight=pxa255#post15275
    Adding support is also not planned as this is a depreciated for Intel specialized ARM architecture with little to no market for us.
