I have a task for file download, which need to update a progress bar.
so the download task send a message of the current progress bar value by a call to this function:
void dl_setProgBar(int prc)
dlMsg.MsgId = dlProgBarEvent;
dlMsg.Data.v = prc;
// WM_SendMessage(dl_hWin,&dlMsg); // does not work
WM_BroadcastMessage(&dlMsg); // working
When I send the message to the window that contains the progbar, it does not generate the notification, but if I broadcast it - it works.
The call back for this window looks like:
static void _cbDialog(WM_MESSAGE * pMsg) {
WM_HWIN hItem;
int NCode;
int Id;
// USER START (Optionally insert additional variables)
// USER END
switch (pMsg->MsgId) {
case dlProgBarEvent:
hItem = WM_GetDialogItem(pMsg->hWin, ID_PROGBAR_0);
PROGBAR_SetValue(hItem,pMsg->Data.v);
break;
case WM_INIT_DIALOG:
What am I missing? Why I can't send the message to that window only?
Johanan
dlMsg.Data.v = prc;
WM_HWIN hItem;
int NCode;
int Id;
// USER END
break;
Johanan
