[ABANDONED] ST-Link to J-Link/J-Trace on STM32L476RC
  • [ABANDONED] ST-Link to J-Link/J-Trace on STM32L476RC
    Hi, trying to switch from ST-Link to J-Link without much success.
    A- STM32L476RCTx based custom board
    B- OpenSTM32 / AC6 GCC based toolchain
    C- Nucleo-64 L476RG based ST-Link v2.1 debugger
    D- Using 'STM32 ST-LINK Utility.exe', did a 'Erase Chip'.
    0x1FFF7800 = FFEFF8AA 00100755 FFFFFFFF 00000000
    0x1FFF7810 = 7FFF0000 8000FFFF FF00FFFF 00FF0000
    0x1FFF7820 = FF00FFFF 00FF0000 FFFFFFFF FFFFFFFF
    Works, slow but works (limited to 4 breakpoints though, if you want to have success with 'step out'/'run to')
    -> log_stlink.txt
    E- Added GNU MCU Eclipse plugin from gnu-mcu-eclipse.github.io/plugins/install/
    F- Made a connector custom bridge gnu-mcu-eclipse.github.io/developer/j-link-stm32-boards/
    G- Connected the J-Link, configured a 'GDB SEGGER J-Link Debugging' based configuration (default)
    This doesn't work like expected, flash is not performed successfully, PC get stuck somewhere in a rather random place.
    H- To be sure it is not a bridge problem, I removed J-Link and switched to ST-Link firmware from segger.com/products/debug-prob…j-links/st-link-on-board/
    I- Executed 'JLinkSTM32.exe' (11) then 'JLink.exe' to get option bytes ('mem32 0x1FFF7800,C')
    Got the same problem.
    -> log_jlink_flash.txt
    Any idea ?
    To understand your setup correctly, you use the ST-Link on the Nucleo board as debug out to debug an STM32L4 on a custom board?
    Is that correct?
    Is there a specific reason why not simply use the J-Link you have registered with in the forum?
    When using the converted ST-Link, can you connect to the target device at all?
    Could you crosscheck this with the J-Link Commander and post your results? wiki.segger.com/J-Link_cannot_…ty_using_J-Link_Commander
  • Yeah, the original development took place using ST-Link.
    I then switched to J-Link/J-Trace (using GNU MCU Eclipse) but no luck.
    Tried to switch back to ST-Link but converted to J-Link but no luck either.
    So the problem is not the bridge (connector)
    Is the problem from the j-Link firmware (option byte, flashing dual bank) ?
    I will try J-Link Commander asap.
