Hi everyone!
I have just recently got a Flasher portable plus and programming and nRF 51822 AC with it. So I have been using J Flash software v6.22d. I had opened the .hex file by File->Open Data File
and it opens correctly. I connected my Flasher Portable Plus into the PC and selected File->Download Config and Data File to flasher. It downloads the "Flasher.cfg" and "Flasher.dat" file into the Flasher Portable Plus "Image 1" slot. And I also programmed my board using "PROG" button on the flasher and it works fine.
But I want to load more than one .cfg and .dat file into the Flasher Portable Plus into different image slot so that I can program the boards easily by just selecting the image using "SEL" on the flasher. But when i open another .hex file and select File->Download Config and Data File to flasher . It seems that it overwrites the old Flasher.cfg and Flasher.dat file into the same Image slot without saving it to the other image slot like "Image 2". Basically so its like i can only store one image at a time in the flasher portable plus which is quiet inconvenient.
I know this is a newbie question but help will be highly appreciated, since i am new to this platform.
Thanks!
Thanks!
The post was edited 1 time, last by ahmed.hussain ().
