[SOLVED] Show Large Toolbar icons does not work
  • [SOLVED] Show Large Toolbar icons does not work
    Show Large Icons in Toolbar does not work. The setting for Tools->Options->Environment->Show Large Icons in Toolbars is set to Yes as can be seen in the first attachment.
    The actual SES window with tiny toolbar icons is shown in the second attachment.
    BTW, I was able to increase the Application Main Font and Application Monospace font and SES responded nicely! It's only the Toolbar icon is tiny and does not respond to the setting.
    If it helps, I'm using a 15" Surface Book 2 running Windows 10 Pro 1709 OS Build 16299.125 with default settings for the display.
    I would appreciate your help in resolving this issue. If you need further info, I'd be glad to provide it.
    Kannan
    PS: There was a similar thread but I could not update that with attachments so I started a new one.
    This issue should already be fixed in the current release version.
    Simply update Embedded Studio and you should be good to go.
  • Hi Kannan,
    Alright, much success with your project.
    This case will be considered as closed now.
