LISTVIEW_GetSel() function always returning 0 after vertical scrollbar has been moved.
  • LISTVIEW_GetSel() function always returning 0 after vertical scrollbar has been moved.
    I am writing an application running on a STM32 processor using the STemWin precompiled library based on emWin version 5.40.
    I am using a 'LISTVIEW' object in my application to list 100 items for the user to select from.
    I am able to select an item from the list and the index is returned correctly until the vertical scrollbar is moved, once the vertical scrollbar has been moved the LISTVIEW_GetSel() function is always returning the value 0 regardless of the selection in the 'LISTVIEW'.
    Here is a snippet of my window callback which handles this...
    1. static int selected;
    2. case WM_NOTIFY_PARENT:
    3. Id = WM_GetId(pMsg->hWinSrc);
    4. NCode = pMsg->Data.v;
    5. switch(Id) {
    6. case ID_LISTVIEW_0: // Notifications sent by 'Listview'
    7. switch(NCode) {
    8. case WM_NOTIFICATION_CLICKED:
    9. WM_HideWindow(_hNumKeyboard);
    10. break;
    11. case WM_NOTIFICATION_RELEASED:
    12. break;
    13. case WM_NOTIFICATION_SEL_CHANGED:
    14. hItem = WM_GetDialogItem(pMsg->hWin, ID_LISTVIEW_0);
    15. selected = LISTVIEW_GetSel(hItem);
    16. break;
    17. }
    18. break;
    I have tried using the auto scroll bar function and have also tried adding the scrollbar manually but both scenarios yield the same result.
    I would appreciate it if you have any suggestions as to what might be going wrong here. Hopefully I am just missing something obvious!
    Thank you in advance.
    Kind Regards,
    Pete
  • Hello Pete,
    I have tried to reproduce this but it is working on my side. I have tested with the latest version of emWin as well as with V5.40.
    Here is the code I have used for testing:
    1. #include "DIALOG.h"
    2. #include <stdio.h>
    3. /*********************************************************************
    4. *
    5. * Defines
    6. *
    7. **********************************************************************
    8. */
    9. #define ID_WINDOW_0 (GUI_ID_USER + 0x00)
    10. #define ID_LISTVIEW_0 (GUI_ID_USER + 0x02)
    11. /*********************************************************************
    12. *
    13. * Static data
    14. *
    15. **********************************************************************
    16. */
    17. /*********************************************************************
    18. *
    19. * _aDialogCreate
    20. */
    21. static const GUI_WIDGET_CREATE_INFO _aDialogCreate[] = {
    22. { WINDOW_CreateIndirect, "Window", ID_WINDOW_0, 0, 0, 480, 272, 0, 0x0, 0 },
    23. { LISTVIEW_CreateIndirect, "Listview", ID_LISTVIEW_0, 10, 10, 302, 252, 0, 0x0, 0 },
    24. };
    25. /*********************************************************************
    26. *
    27. * Static code
    28. *
    29. **********************************************************************
    30. */
    31. /*********************************************************************
    32. *
    33. * _cbDialog
    34. */
    35. static void _cbDialog(WM_MESSAGE * pMsg) {
    36. WM_HWIN hItem;
    37. int NCode;
    38. int Id;
    39. char acBuffer[64];
    40. int Sel;
    41. int i;
    42. switch (pMsg->MsgId) {
    43. case WM_INIT_DIALOG:
    44. //
    45. // Initialization of 'Listview'
    46. //
    47. hItem = WM_GetDialogItem(pMsg->hWin, ID_LISTVIEW_0);
    48. LISTVIEW_AddColumn(hItem, 100, "Col 0", GUI_TA_HCENTER | GUI_TA_VCENTER);
    49. LISTVIEW_AddColumn(hItem, 100, "Col 1", GUI_TA_HCENTER | GUI_TA_VCENTER);
    50. LISTVIEW_AddColumn(hItem, 100, "Col 2", GUI_TA_HCENTER | GUI_TA_VCENTER);
    51. for (i = 0; i < 100; i++) {
    52. LISTVIEW_AddRow(hItem, NULL);
    53. sprintf(acBuffer, "Item %i", i);
    54. LISTVIEW_SetItemText(hItem, 0, i, acBuffer);
    55. }
    56. LISTVIEW_SetAutoScrollV(hItem, 1);
    57. LISTVIEW_SetGridVis(hItem, 1);
    58. break;
    59. case WM_NOTIFY_PARENT:
    60. Id = WM_GetId(pMsg->hWinSrc);
    61. NCode = pMsg->Data.v;
    62. switch(Id) {
    63. case ID_LISTVIEW_0: // Notifications sent by 'Listview'
    64. switch(NCode) {
    65. case WM_NOTIFICATION_CLICKED:
    66. break;
    67. case WM_NOTIFICATION_RELEASED:
    68. break;
    69. case WM_NOTIFICATION_SEL_CHANGED:
    70. hItem = WM_GetDialogItem(pMsg->hWin, ID_LISTVIEW_0);
    71. Sel = LISTVIEW_GetSel(hItem);
    72. break;
    73. }
    74. break;
    75. }
    76. break;
    77. default:
    78. WM_DefaultProc(pMsg);
    79. break;
    80. }
    81. }
    82. /*********************************************************************
    83. *
    84. * Public code
    85. *
    86. **********************************************************************
    87. */
    88. /*********************************************************************
    89. *
    90. * MainTask
    91. */
    92. void MainTask(void) {
    93. GUI_Init();
    94. GUI_CreateDialogBox(_aDialogCreate, GUI_COUNTOF(_aDialogCreate), _cbDialog, WM_HBKWIN, 0, 0);
    95. while (1) {
    96. GUI_Delay(100);
    97. }
    98. }
    99. /*************************** End of file ****************************/
    For now I can't say what is going wrong on your side. Please give it a try and check if the code above runs.
  • Hi Sven,
    Thank you for your fast response.
    I added your code to my application as a new module and when called it does indeed work correctly, so that leaves me thinking I have probably done something stupid in the module that is coursing me a problem.
    I have attached the code for the entire module, it would be much appreciated if you wouldn't mind taking a quick look to see if there is anything obviously wrong that might break the LISTVIEW_GetSel() function.
    Thanks again.
    Kind Regards,
    Pete
    • point.zip
      (2.86 kB, downloaded 79 times, last: )
    I checked your application, but I couldn't find anything obvious. I modified it a little bit to be able to let in run in the simulation (deleting unknowns), but it was working. I always get the proper selection, no matter if I use the scrollbar.
    Attached is my modified version.
    Not sure if this will help, but did you tried to increase the emWin memory (most likely in GUIConf.c)?
  • Hi Sven,
    Thank you again for your fast response.
    I monitor the free GUI memory all the time and it never gets below about 2MB so I don't think there is a memory allocation issue. It is however worrying that this is happening as it suggests stack corruption or something of that nature. I will have to look into the application as a whole now see if I can see what is going wrong.
    Thank you for your time and confirming there are no known issues with the 'LISTVIEW' item at this time.
    I will continue to look into the issue here.
    Cheers,
    Pete
