[ABANDONED] Bootloader
  • Hello Ilkay,
    J-Link will only reprogram memory sections that have changed. So make sure that your debug build does not generate any code for 0x08000000 - 0x08003FFF.
    Could you provide us with a J-Link log file when that happens? wiki.segger.com/Enable_J-Link_log_file
    Would it be possible for you to send us an example project where this issue is reproducible?
  • Hello Nino,
    You can find my elf file attached.
    ELF Header is below.
    When I connect using Target/Connect J-Link/Verify , it's output is; ( it flashes bank 0 (0x08000000 - 32K )
    Connecting ?J-Link? using ?USB?
    Connecting to target using SWD
    Loaded /Applications/SEGGER Embedded Studio for ARM 3.34/bin/libjlinkarm.dylib
    Firmware Version: J-Link Pro V4 compiled Dec 12 2017 14:34:30
    DLL Version: 6.22d
    Hardware Version: V4.00
    Target Voltage: 4.603
    Device "STM32F207VE" selected.
    AP[0]: Core found
    CPUID register: 0x412FC230. Implementer code: 0x41 (ARM)
    Found Cortex-M3 r2p0, Little endian.
    CoreSight components:
    ROMTbl[0] @ E00FF000
    ROMTbl[0][0]: E000E000, CID: B105E00D, PID: 002BB000 SCS
    ROMTbl[0][1]: E0001000, CID: B105E00D, PID: 002BB002 DWT
    ROMTbl[0][3]: E0000000, CID: B105E00D, PID: 002BB001 ITM
    ROMTbl[0][4]: E0040000, CID: B105900D, PID: 002BB923 TPIU-Lite
    ROMTbl[0][5]: E0041000, CID: B105900D, PID: 002BB924 ETM-M3
    Downloading ?STM18.elf? to J-Link
    Programming 16.7 KB of addresses 08004000 ? 08008327
    Programming 0.1 KB of addresses 08008328 ? 080083ef
    J-Link: Flash download: Bank 0 @ 0x08000000: 1 range affected (32768 bytes)
    J-Link: Flash download: Total time needed: 0.925s (Prepare: 0.012s, Compare: 0.023s, Erase: 0.781s, Program: 0.103s, Verify: 0.000s, Restore: 0.002s)
    Download successful-------------------------------------------------------------------------------------------------
    But when I try to debug ;
    Class: ELF32
    Encoding: Little endian
    ELFVersion: Current
    Type: Executable file
    Machine: ARM
    Version: Current
    Entry: 0x80079e5
    Flags: 0x5000200
    Section Headers:
    [ Nr ] Type Addr Size ES Flg Lk Inf Al Name
    [ 0] NULL 00000000 00000000 00 00 000 00
    [ 1] PROGBITS 08004000 00004488 00 AX 00 000 04 .text
    [ 2] ? (0x70000001) 08008488 00000008 00 A 01 000 04 .ARM.exidx
    [ 3] PROGBITS 20000184 000000c8 00 WA 00 000 04 .data
    [ 4] NOBITS 20000250 00005a2c 00 WA 00 000 08 .bss
    [ 5] ? (0x70000003) 00000000 0000002b 00 00 000 01 .ARM.attributes
    [ 6] PROGBITS 00000000 0000007e 01 00 000 01 .comment
    [ 7] PROGBITS 00000000 0006c710 00 00 000 01 .debug_info
    [ 8] PROGBITS 00000000 0000c3b7 00 00 000 01 .debug_abbrev
    [ 9] PROGBITS 00000000 0001443c 00 00 000 01 .debug_loc
    [ 10] PROGBITS 00000000 00001b40 00 00 000 08 .debug_aranges
    [ 11] PROGBITS 00000000 000026f8 00 00 000 08 .debug_ranges
    [ 12] PROGBITS 00000000 0003823b 00 00 000 01 .debug_macro
    [ 13] PROGBITS 00000000 0002cd99 00 00 000 01 .debug_line
    [ 14] PROGBITS 00000000 0010ff79 01 00 000 01 .debug_str
    [ 15] PROGBITS 00000000 000056c0 00 00 000 04 .debug_frame
    [ 16] SYMTAB 00000000 00003d80 10 11 265 04 .symtab
    [ 17] STRTAB 00000000 0000241b 00 00 000 01 .strtab
    [ 18] STRTAB 00000000 000000c3 00 00 000 01 .shstrtab
    Key to Flags: W (write), A (alloc), X (execute)
    Segment headers:
    [ Nr ] Type VirtAddr PhysAddr FileSize Mem.Size Flags Align
    [ 0] ? (0x70000001) 08008488 08008488 00000008 00000008 R 00000004
    [ 1] LOAD 08004000 08004000 00004490 00004490 RX 00000004
    [ 2] LOAD 20000184 08008490 000000c8 000000c8 RW 00000004
    [ 3] LOAD 20000250 08008560 00000000 00005a2c RW 00000008
    • STM18.zip
      (693.32 kB, downloaded 79 times, last: )
  • Hello Ilkay,
    The logs you provided are not helping.
    Could you provide a J-Link logfile as described in the wiki? wiki.segger.com/Enable_J-Link_log_file
    For reference, could you test if debugging the elf in Ozone works? segger.com/products/development-tools/ozone-j-link-debugger/
    Create a ne ozone project with the project wizard and select your elf file when asked for the Program File.
    Does that work for you?
