MULTIPAGE_IsPageEnabled index
  • MULTIPAGE_IsPageEnabled index
    I am trying to use MULTIPAGE_IsPageEnabled to detect if a specific page is enable to automatically update a TEXT widget on the page. MULTIPAGE_IsPageEnabled is being called from an interrupt routine and I don't want to update it if the page is not enabled as that appears to cause the system to crash. My problem is the index. The page I am concern with is the second of 2 pages i . MULTIPAGE_IsPageEnabled returns true with both 0 and 1 index values when the page is not enabled and the value gets updated. If I use 2 or higher for the index the if statement never evaluates true. Below is code from main.c that creates the pages and my interrupt callback.
    in main.c
    hMultipage0 = MULTIPAGE_CreateEx(GUI_SCALE_RECT(10, 10, 300, 220), 0, WM_CF_SHOW, 0, GUI_ID_MULTIPAGE0);
    WM_HWIN hPageWin;
    hPageWin = WINDOW_CreateEx(GUI_SCALE_RECT(0, 0, 300, 200), WM_HBKWIN, 0, 0, GUI_ID_PAGEWIN1, cbPageWin1);
    MULTIPAGE_AddPage(hMultipage0, hPageWin, "Sliders & spinbox");
    /* Create widgets on page 2 */
    hSlider0 = SLIDER_CreateEx(GUI_SCALE_RECT(60, 160, 200, 30), hPageWin, WM_CF_SHOW, 0, GUI_ID_SLIDER0);
    SLIDER_SetWidth(hSlider0, GUI_SCALE(10));
    SLIDER_SetValue(hSlider0, 50);
    hSlider1 =
    SLIDER_CreateEx(GUI_SCALE_RECT(10, 10, 30, 180), hPageWin, WM_CF_SHOW, SLIDER_CF_VERTICAL, GUI_ID_SLIDER1);
    SLIDER_SetWidth(hSlider1, GUI_SCALE(10));
    SLIDER_SetValue(hSlider1, 50);
    hSpinbox0 = SPINBOX_CreateEx(GUI_SCALE_RECT(100, 80, 100, 50), hPageWin, WM_CF_SHOW, GUI_ID_SPINBOX0, 0, 100);
    SPINBOX_SetFont(hSpinbox0, GUI_LARGE_FONT);
    SPINBOX_SetValue(hSpinbox0, 50);
    hProgbar0 =
    PROGBAR_CreateEx(GUI_SCALE_RECT(60, 10, 200, 40), hPageWin, WM_CF_SHOW, PROGBAR_CF_HORIZONTAL, GUI_ID_PROGBAR0);
    PROGBAR_SetFont(hProgbar0, GUI_LARGE_FONT);
    PROGBAR_SetValue(hProgbar0, 50);
    hPageWin = WINDOW_CreateEx(GUI_SCALE_RECT(0, 0, 300, 200), WM_HBKWIN, 0, 0, GUI_ID_PAGEWIN2, cbPageWin2);
    MULTIPAGE_AddPage(hMultipage0, hPageWin, "readout");
    hText0 = TEXT_CreateEx(10,10,100,20, hPageWin, WM_CF_SHOW, TEXT_CF_LEFT | TEXT_CF_VCENTER,GUI_ID_TEXT0,string);
    hText1 = TEXT_CreateEx(340,10,100,20, hPageWin, WM_CF_SHOW, TEXT_CF_LEFT | TEXT_CF_VCENTER,GUI_ID_TEXT0,time_string);
    TEXT_SetTextColor(hText0,GUI_RED);
    interrupt callback
    void HAL_RTCEx_AlarmBEventCallback(RTC_HandleTypeDef *hrtc)
    HAL_RTC_GetTime(hrtc, &sTime, FORMAT_BIN);
    HAL_RTC_GetDate(hrtc, &sDate, FORMAT_BCD);
    sprintf(time_string, "%02d:%02d:%02d", sTime.Hours,sTime.Minutes,sTime.Seconds);
    TEXT_SetText(hText1, time_string);
    if(MULTIPAGE_IsPageEnabled (hMultipage0, 1))
    WM_Exec();
    Frank
    Did you disabled the second page at one point?
    I'm asking because a page will return true when calling MULTIPAGE_IsPageEnabled(), even though it is currently not shown. Maybe MULTIPAGE_GetSelection() is what you should use.
    If you don't want to update the TEXT widget if page 1 is not visible you should also place the TEXT_SetText() call into the if condition, like:
    1. if (MULTIPAGE_GetSelection(hMultipage0) == 1) {
    2. HAL_RTC_GetTime(hrtc, &sTime, FORMAT_BIN);
    3. HAL_RTC_GetDate(hrtc, &sDate, FORMAT_BCD);
    4. sprintf(time_string, "d:d:d", sTime.Hours,sTime.Minutes,sTime.Seconds);
    5. TEXT_SetText(hText1, time_string);
    6. WM_Exec();
    7. }
    Otherwise it might happen that the TEXT widget gets invalidated at the next call of WM_Exec()/GUI_Exec()/GUI_Delay().
    Another thing is, that we recommend to call functions like GUI_Exec(), WM_Exec() or GUI_Delay() from only one point in your application. A bit like this:
    1. void TimerInterrupt(void) {
    2. TEXT_SetText(hText, "New Text"); // Marks the Text widget also as invalid
    3. }
    4. void MainTask(void) {
    5. GUI_Init();
    6. hText = TEXT_CreateEx(10, 10, 80, 20, WM_HBKWIN, WM_CF_SHOW, 0, GUI_ID_TEXT0, "Text");
    7. while (1) {
    8. GUI_Delay(100); // Redraws all invalid windows among other things, would work with GUI_Exec() as well
    9. }
    10. }
  • Thanks for the advice Sven. Your recommendations fixed the issue. I did not disable the page when it was not selected as I was unaware that the page would still be enabled when it is not the selected (top) page. I also took your advice about calling WM_Exec from only one point in the code.
    Frank
